MANUAL TO POWER STEERING SWAP - need help
Old Nov 8, 2007 | 06:22 AM
drumminforev's Avatar
Default MANUAL TO POWER STEERING SWAP - need help
I have a 93 dx, with b16a2 2000 si motor installed. I got the ps rack, and now ill put it in.
my problem is i need a pump and bracket, but dont know which to get. They keep asking what "ID' number i need for the pump and bracket. Does anyone know. Its just normal b16a2
Old Nov 8, 2007 | 07:32 AM
Relic1's Avatar
logically since the pump and mounts fasten to the engine, you need the pump and mounts for the 2000 SI.
all though I don't know for sure.
Old Nov 11, 2007 | 12:01 AM
Default Re: (Relic1)
BUMP someone i know can answer this just spend a few seconds to reply. Is my 93 power steering rack going to connect to my 2000 si pump?
Old Nov 11, 2007 | 12:12 AM
n1_egsex's Avatar
* B A N N E D *
Default Re: (drumminforev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">BUMP someone i know can answer this just spend a few seconds to reply. Is my 93 power steering rack going to connect to my 2000 si pump?</TD></TR></TABLE>
no it wont
eg's have the small offset hole ps pump, ek's and dc2's have the inline big hole ps pumps
96-00 civic/94-01 integra on the left, 92-95 civic on the right
Old Nov 11, 2007 | 02:04 PM
Default Re: (n1_egsex)
so then since i cant do that....could i use the 96-00 ps rack and mount that to my 93dx steering column..
if so then im problem free
Old Nov 14, 2007 | 08:51 AM
come on guys, simple question!
can i just use the 96-00 rack
do i need specifially the 99-00 SI rack?
or is it possible just to swap lines and use the 93 ps rack with the 00 ps pump....any reason why i couldnt switch the lines?
Old Nov 14, 2007 | 08:54 AM
ORRR
is there some way to MOUNT THE 93 PS PUMP to my b16? Do i need a custom braket or what?
thanks
Old Nov 14, 2007 | 09:07 AM
Relic1's Avatar
if all else fails... try it. and post up what you find.
Old Nov 15, 2007 | 12:38 PM
bump, i helped this forum out with my AC GANGSTA thread, so dont see why anyone shouldnt help me.
Old Nov 15, 2007 | 12:44 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">bump, i helped this forum out with my AC GANGSTA thread, so dont see why anyone shouldnt help me.</TD></TR></TABLE>
relax man! just because you might have done the a/c thread doesn't mean every member on here has to stop what they are doing to post for you. remember, there are alot of new members on here, some learning as they go, you know.
as for your question. if you are using a PS system of any 92-95 civic, then you are going to have to get the pump and brackets off of a 94-95 del sol (b16a3).
this will bolt straight up without any problem.
as for a 96-00 system, not sure if the line from the pump to the rack is the same, but i know for sure you cannot use the rack on your 93 civic. the subframe is alittle different.
Old Nov 15, 2007 | 02:38 PM
ejoner's Avatar
Default Re: (philosofy1)
If you get the 96-00 rack then the lines are going to be different and your going to need the 96-00 pump. I say just find a 92-95 rack,lines,and pump. This way you will not run into any problems.
Old Nov 17, 2007 | 10:07 AM
Default Re: (ejoner)
The problem there is my engine is 2000, so how is a 93 rack pump and alll that going to work.
OK IM ASKING SIMPLE QUESTION
WHICH PUMP DO I USE.I have 93 civic with b16 sawp.
DO I USE 92-95 rack and pump OR 96-00 RACK AND PUMP, OR MIX THEM, AND WHICH WAY WOULD I MIX.
Old Nov 17, 2007 | 10:47 AM
CapnKrunch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev &raquo;</TD></TR><TR><TD CLASS="quote">[B]The problem there is my engine is 2000, so how is a 93 rack pump and alll that going to work. </TD></TR></TABLE>
It doesn't matter what year your engine is. Its just that the 93 del sol is a B series and your motor is a B series thats all that matters.
Old Nov 17, 2007 | 11:47 AM
duggy's Avatar
I don't know if this helps any.
I did a B20 swap into a 99 Civic Sedan.
I used the B20 PS bracket, and the stock 99-00 civic PS Pump.
I assume you will have to get the B16 PS bracket, and lines, rack, and pump from a 92-95.
99R-type
May 12, 2011 04:29 AM
94CivicSi
Jul 31, 2008 08:34 AM
ham
Mar 28, 2008 06:35 AM
Rus1an
Dec 30, 2006 08:09 PM
EK9Greg
Sep 9, 2004 04:03 AM
