Will Master and slave clutch cylinder for a f22 fit a f23a1?
As long as the F23 is not in a 98-02 accord then yes it will work. If you have one of those accords the clutch line is different and it uses a roll pin on the slave cyl and a hugh cotter for the master cyl. If you want to use the F22 ones you will need to swap out the clutch line if its going in a 98-02 accord
oh yeah, I remember someone wanting to do SS braided line on a 98-02 auto-5spd swap and didn't because the fittings where different.
what difference would it make, it just said f22 between the the years of 90-97, which one out of those f22's would have worked with a f23a1?
does anyone know abotu the tsb on it, my friend told me that theres something about if its nylon then the whole hydrulic system needs to be replaced? i didnt have enough time to get more info from him but im gonna swing by the shop the tsb up, anyone else heard of this?
westcoastaccord
Jun 24, 2016 12:34 PM
