Anyone have a DIY write up on a rear motor mount????
Old Nov 8, 2007 | 05:00 AM
DeDonDeRosa's Avatar
Default Anyone have a DIY write up on a rear motor mount????
just wanted to know if anyone has a diy write up for the rear motor mount. i keep hearing that its a PITA to do. so just wanted to see if anyone could help by havin a write up. thanks guys
Old Mar 13, 2010 | 08:29 AM
cookiemonsta08's Avatar
Default Re: Anyone have a DIY write up on a rear motor mount????
nobody seems to help.... even this old as$ thread got no help!
Old Mar 13, 2010 | 12:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Well you pretty much just unbolt the old one and bolt the new one in. However I replaced mine when I had my intake manifold removed, so that made it so much easier. But of course getting the IM off and back on was a major PITA.
Old Mar 13, 2010 | 12:39 PM
SpeedRacerEX-R's Avatar
I usually unbolt the passenger side mounts that way I can jack the motor up and down to work the mount out.
Old Mar 13, 2010 | 01:09 PM
Hogslayer's Avatar
TRIAL USER
when i put the motor in my DA, i put the bolts in for the two side mounts first (didnt tighten them down) and then the rear one. having just the side ones in allowed the motor to move just enough to jockey it into place. i too had the exhaust pipe off. it was a bit of a PITA as you say (lol) since the rear one is shaped kinda weird, so having room to work definitely made it easier. it was a little frustrating since i didnt take it off, or see my friend take it off, but if you look at it you can see how it goes on. i hope that this has been at least encouraging, if not helpful.
Old Mar 13, 2010 | 01:51 PM
skipper28-DC's Avatar
u may need the cherrypic
Old Mar 13, 2010 | 09:44 PM
ok i did it!! what a PITA though... the hardest part was trying to remove the T bracket on the rear mount. I couldn't remove it w/o remove a ton of hoses so i work my way around it and was able to remove and install the rear wount with the T bracket loose. much stiffer now the motor is so snugg with these innovative mounts
Old Mar 14, 2010 | 05:05 AM
Community Builder
meh I had poly inserts in just the 2 front lower mounts and the whole car vibrated like hell at idle. I didn't even bother trying to put the rear one in. I yanked the front inserts out and replaced it with new OEM mounts.
Old Mar 14, 2010 | 09:56 PM
i have a slight vibration but doesn't bother me much, kinda like having a exhuast
NOman0608
Apr 6, 2009 05:02 PM
Draggin99Si
Jul 27, 2006 06:52 PM
SoEvoL
Jul 14, 2006 08:27 PM
Black R
Jan 31, 2004 07:34 AM
Kato7997
Mar 4, 2003 06:03 PM
