Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods....
Old Nov 8, 2007 | 03:37 AM
0TT's Avatar
0TT
Default Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods....
on the 96-00 civic EK or Civic Type-R etc... Id like to mount three gauge pods into the space where the pocket is currently.
Does anywhere sell a pod like I need?
its to go in the pocket at the top of this picture
Click to enlarge..
Old Nov 8, 2007 | 04:27 AM
quicksilver1689's Avatar
i ♥ snails
maybe a din blockoff plate from the type R? then drill out three holes for the guages, or a carbon fiber plate with the same idea.
Old Nov 8, 2007 | 04:34 AM
0TT's Avatar
0TT
thats the kind of thing that im thinking but if theres anything off the shelf it'd be alot neater.
Old Nov 8, 2007 | 04:37 AM
newby_j's Avatar
Needs More Cowbell
Default Re: (0TT)
i think that defi makes a plate thing with 3 gauges in it....$ though
Old Nov 8, 2007 | 05:04 AM
0TT's Avatar
0TT
Sizes are:
1-Din radio size is= 7.5"x2.5"
Pocket is 7.5x2, surrounding fascia area is 8.25x3.75" and 3.25 deep.
Old Nov 8, 2007 | 06:44 AM
MugenManR's Avatar
Default Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (0TT)
whats the black box for under the cup holder.
Old Nov 8, 2007 | 07:06 AM
0TT's Avatar
0TT
Clifford Concept 650 MK2 alarm system that also has remote start, turbo timer, window roll-up/venting by remote, dual zone proximity sensor, digital tilt & motion sensor, black-jax anti-hijacking and various other othtions.
Its a fresh inport from Japan, EK9, extremly clean, inside and out. So I didnt want to take my chances with having it stolen as NO japanese car comes with an alarm, some newer ones come with transponder immobiliser key but not the 98 Civic Type-R which is what mine is.
Old Nov 8, 2007 | 07:07 AM
0TT's Avatar
0TT
bump for more ideas / help
bobobob's Avatar
Default Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (MugenManR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR &raquo;</TD></TR><TR><TD CLASS="quote">whats the black box for under the cup holder. </TD></TR></TABLE>
Looks like a main unit for a alarm.
I've place my radio in that pocket, so its the same size as the upper one.
Easiest way is probably using a block off plate with three holes.
Old Nov 8, 2007 | 07:11 AM
0TT's Avatar
0TT
Default Re: Can you put gauges in this pocket in the Civic EK / CTR? & who sells gauge pods.... (bobobob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobobob &raquo;</TD></TR><TR><TD CLASS="quote">
Easiest way is probably using a block off plate with three holes.</TD></TR></TABLE>
Sizes are:
Not the same size!
Old Nov 8, 2007 | 07:35 AM
0TT's Avatar
0TT
If you have a radio in place of this pocket then please give me your cars make/model so I can order this part to use on my car.
Cheers
Old Nov 8, 2007 | 07:46 AM
ariza034's Avatar
Default Re: (0TT)
something like this
http://www.kdmstuff.com/shop/step1.php?number=1992
or
http://www.kdmstuff.com/shop/step1.php?number=131
Old Nov 8, 2007 | 07:56 AM
0TT's Avatar
0TT
Default Re: (ariza034)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ariza034 &raquo;</TD></TR><TR><TD CLASS="quote">something like this..</TD></TR></TABLE>
I have ordered the triple-gauge single-din pod like in the website BUT, I need the part of the factory centre console that IS 1-DIN sized so I can put it in
Old Nov 8, 2007 | 11:07 AM
bobobob's Avatar
ok maybe i said it wrong. i've replaced the pocket with my radio.
i have a 96 EK4
Old Nov 8, 2007 | 11:11 AM
Bazza's Avatar
you need to get a block off plate.. nobody makes a guage pod for that spot. just get a block off plate... Drill the holes for your guages put em in and wire em up... its actually simple..
52mm drill bit.
the block off plate
drill.
only things youll really need.
Old Nov 8, 2007 | 11:22 AM
GG99's Avatar
Default Re: (Bazza)
^ yep.
heres a pic of someone doing it in an integra.
Old Nov 12, 2007 | 01:15 AM
0TT's Avatar
0TT
Thanks guys, ive realised i measured the outer edge of the radio fascia, not the actual size. D'oh.
Im ordering a 1-DIN sized triple guage pod from a tuning shop here.
Jakester9500
Sep 1, 2008 05:14 AM
ken00si
24
May 12, 2006 02:13 PM
coll9947
Dec 14, 2005 05:34 AM
sakums20
Mar 15, 2004 07:43 AM
