is this normal for new motor???
Old Nov 7, 2007 | 08:17 PM
ls19integra95's Avatar
Default is this normal for new motor???
so i spun a rod bearing and had my engine rebuilt, sleeved, bored, balanced with all new internals that where aftermarket and i then was told to drive it around for a lil while to break it in, im at 600miles and i checked the oil to make sure no metal shavings because i have a magnetic drainplug... it has some metal on it but its not like big pieces or chunks or anything... its exactly what you get out of a differentil on a magnetic plug... just that little bit of fine metal from wear and tear... the engine seems fine and runs fine also... now remember, this is a completely rebuilt motor with all new parts... wanted to know if i would see a little bit of metal like that for a lil while because of break in or what?
Old Nov 7, 2007 | 08:45 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: is this normal for new motor??? (ls19integra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 &raquo;</TD></TR><TR><TD CLASS="quote">so i spun a rod bearing and had my engine rebuilt, sleeved, bored, balanced with all new internals that where aftermarket and i then was told to drive it around for a lil while to break it in, im at 600miles and i checked the oil to make sure no metal shavings because i have a magnetic drainplug... it has some metal on it but its not like big pieces or chunks or anything... its exactly what you get out of a differentil on a magnetic plug... just that little bit of fine metal from wear and tear... the engine seems fine and runs fine also... now remember, this is a completely rebuilt motor with all new parts... wanted to know if i would see a little bit of metal like that for a lil while because of break in or what?</TD></TR></TABLE>
yep. the sleeves will loosen up. The rings will wear down. The bearings will seat in. The tolerances are a little tight on new motors. Once everything is "comfy", you should stop seeing a lot of shavings.
Old Nov 7, 2007 | 08:46 PM
Default Re: is this normal for new motor??? (B serious)
ok cool thanks, thats what i was thinking and i just wanted to make sure...
rich7777
Aug 5, 2010 08:49 AM
strtrcr77
Feb 14, 2008 10:13 AM
RCautoworks
40
May 17, 2006 08:23 PM
SPOOLINmatt
Jul 14, 2005 06:07 PM
10K2HVN
Aug 21, 2003 12:14 AM
