Timing belt question....
I searched and found some info on the timing belt but was curious if i should change the tensioner and the water pump if they both appear to be in good working order? thanks
I bought my Es1 with 81K on the Odometer and I had the dealer put a new timing belt and water pump in at the time of purchase. Always a preventitive maintenece step to be taken at your 80,000 mark. Also should be done at 50,000 mile intervals after that.
I have 104k miles on the car. i bought it with that mileage and the previous owner hadn't changed it. I am looking at a kit on ebay that includes everything for under $200. My local dealership wants $750
or more for the replacement.
as a someone that works at a dealer i would say yes to at least the water pump not so much for the tenisor and since u are in there the water pump is easy to take out and yes after a while they do go bad so be better safe then sorry, tenisor go bad but that is few and far between
and if u are working on an ex have fun just more crap u got to move
do tensioner, water pump everything while you're at it. price the kit from the dealer too, I think I paid something like $250 for my kit. make sure you line up everything good, but I'm sure you know that already
i would deff replace the water pump the tensioner probably not the water pump will deff leak before the belt is due to be changed agian
PSU
18
Jan 30, 2010 09:38 AM
EJ8_Enthusiast
Oct 9, 2008 01:03 PM
