Check engine Light On, Need Help!!!
Old Nov 7, 2007 | 01:08 PM
ajbreezay's Avatar
Default Check engine Light On, Need Help!!!
Codes:
2- #2 Heated Oxygen Sensor
41- heated oxygen sensor heater
65- secondary oxygen sensor heater
What do you guys think it might be or it is? Im guessing its the #2 oxygen sensor but i have picked one up from my friend and it still is shooting the same codes any help would be greatly appreciated!
-Aubrey
Old Nov 7, 2007 | 01:16 PM
all-mtr-teg's Avatar
Default Re: Check engine Light On, Need Help!!! (ajbreezay)
im guessing your car is obd2, after you correct the problem, you need to erase the codes from the ecu to turn off the CEL.
Old Nov 7, 2007 | 01:21 PM
ajbreezay's Avatar
Default Re: Check engine Light On, Need Help!!! (all-mtr-teg)
yes its obd2 could you just disconnect the negative battery wire for 1 minute and then try it or do you have to erase it! When i try it this way the light is off for about 8 seconds then it turns backon!
-Aubrey
Old Nov 7, 2007 | 02:34 PM
you need a code scanner to erase the code from the ecu
Old Nov 7, 2007 | 04:25 PM
ajbreezay's Avatar
alright ill try that thanks bro ill keep u posted!
-Aubrey
Old Nov 7, 2007 | 05:05 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">you need a code scanner to erase the code from the ecu</TD></TR></TABLE>
No you dont, disconnecting the battery for a bit will do just fine.
Year and model? Have you checked the fuses?
Old Nov 7, 2007 | 05:46 PM
ajbreezay's Avatar
Default Re: Check engine Light On, Need Help!!! (Chiovnidca)
its a 97 civic dx i checked the fuses under the hood except the big main ones becaus i dont know how to check those like the smaller ones!
-Aubrey
Old Nov 8, 2007 | 03:19 AM
B16B_coupe's Avatar
HRD PKR
did you clear that engine light yet?? and it comes back on still or no?&gt;
Old Nov 8, 2007 | 04:34 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajbreezay &raquo;</TD></TR><TR><TD CLASS="quote">its a 97 civic dx i checked the fuses under the hood except the big main ones becaus i dont know how to check those like the smaller ones!
-Aubrey</TD></TR></TABLE>
Check fuse #15 (7.5amp) in the under dash fuse box.
Old Nov 8, 2007 | 07:53 AM
its an obd2 most store the CEL as a hard code, and like he said what happened, will stay off for a while if you disconnect the battery but will come back on after a few minutes.
Old Nov 8, 2007 | 10:05 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">its an obd2 most store the CEL as a hard code, and like he said what happened, will stay off for a while if you disconnect the battery but will come back on after a few minutes. </TD></TR></TABLE>
It will only come back on if it recodes. Disconnecting the battery will erase all stored diagnostic information.
Old Nov 8, 2007 | 02:35 PM
ajbreezay's Avatar
Chiovnidca you are the man i highly appreciated bro engine light is now off i would rep you on here but i dont know how too but let me know how and i will!+1 for you!
-Aubrey
Old Nov 8, 2007 | 02:40 PM
Chiovnidca's Avatar
Glad to help. Let us know if it comes back on.
Old Nov 8, 2007 | 04:53 PM
ajbreezay's Avatar
will do!
-Aubrey
Ramireg
Feb 9, 2007 07:15 AM
awalp
Nov 15, 2006 08:25 AM
billyhoe
Oct 17, 2004 08:58 AM
kimo98GSR
Jun 30, 2004 09:51 PM
Nos4R2
Feb 18, 2002 03:48 PM
