How do you pull out the heater control panel?
The cable for my heater control pulled off and now I cant figure out how to pull the control panel off.The top wants to pull out along with the bottom but theres something catching on the center of eacj side.
Just keep yankin untill somethin breaks. When it breaks, replace whatever you broke and reinstall
On a more serious note, what kind of integra do you have?
If I remember right you have to start off by removing your hazard switch and defrost swith. They just pop out but be careful with it. Then there should be screws behind that and after that you can pretty much figure out what else has to be taken out.
Does this help?
https://honda-tech.com/zero...96068
http://www.team-integra.net/se...D=586
If not there were 14,000 other results
http://www.google.com/search?h...moval
Results 1 - 10 of about 14,000 for 1994 integra climate control removal
ner0x
Jun 23, 2005 07:17 PM
LSegHatchy
Aug 4, 2004 06:45 PM
