PLEASE HELP!! problems b16 and whole car!!
ok first off i have a 91 crx si with a b16a motor swap. when i got the car it ran fine and great then problems starting coming... my car wouldnt go above 3.5 rpms and was pulling code four (cas) and after some work i finally got that fixed and now i pull 22 which is vtec pressure valve if anyone can give me some info on that? but also my car will only go to 5.5-6 rpm and then when at that level of rpm's my car wont go any further and i throw black smoke. my CEL doesnt come on soon as i start up but after a few seconds and leveling out idle it does. i have a stock PW0 ecu because my other one got stolen and i switched my old dizzy out when i tried to fix the code 4. also sometimes my car will like miss while taking off or just driving ( sudden shake and rapid lunges) ALOT of problems i know and just kinda thrown together but i need some help and i know this would be the best place to ask! so ANY HELP WILL HELP!! PLEASE ive searched all over and cant find anything!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boobiesinmygrill »</TD></TR><TR><TD CLASS="quote">
Holy screen door. You don't know how to use the bold tags, you've made an incredibly hard to read and long post. Break it up a little, use the enter key.
In any case, the black smoke sounds like you're burning a lot of oil, I'd think your rings may be an issue.
Make sure your timing is good, but I'd be wondering about the bottom end at that point.
</TD></TR></TABLE>Holy screen door. You don't know how to use the bold tags, you've made an incredibly hard to read and long post. Break it up a little, use the enter key.
ya sorry its kinda hard to read but i just threw it out there.. but anyways ya im just trying to get as much info on it as i can then go from there. but ya i was thinkin either burnin too much fuel or oil for smoke.. anyone else ideas?!?!
also when i shift into a gear my car usually like sputters and misses like lunges for a sec i kinda already said that but... just figured id throw it out there. anyone ideas? for the whole issue really try and fix the CEL 6 rpm that stuff then work into the smaller things
no i dont. why?
and also!! weird **** today!!
my car battery died... idk how... but then i got jumped and my horn wouldnt work and also my gauges and lights didnt work but my car did go higher in rpm's i could tell and my CEL would bounce off and on kinda. so
i got some major problems i know but just trying to find some help
searched all over for help
so if anyone can help PLEASE POST!!!
Lucky-13
Mar 19, 2007 03:25 PM
91hatch_on17's
12
Mar 22, 2004 02:30 PM
