Suspension & Brakes Theory, alignment, spring rates....
h22 swap..having trouble
Old Nov 6, 2007 | 06:53 PM
sykeek9's Avatar
Default h22 swap..having trouble
ok i been trying to figure this out... my h22a swap into an ek is giving me trouble.. i check everything..the mounts are tighten, the axle r tighten, the hub juss been put in new, i lifted the car 2 inches,new tires ,new half shaft...hasport complete axle and mounts.. and the car still shakes... its not a little shake its a big shake.. feels like the tires r bouncing off the ground. let say if ur driving it the seat feels like its giving a masage...took it to hasport and the honda dealership and they couldnt figure it out..is there anything else i should do??? if not, i have no choice to sell my motor which i dont want, cuz i spent too much $ on it...and go to plan B..k20R.. please help
Old Nov 7, 2007 | 09:35 AM
ED8dohcZC's Avatar
Default Re: h22 swap..having trouble (sykeek9)
A little more detail. What RPM ranges does it shake or does it shake all the time? Try taking it to a different shop that specializes in engine swaps and such.
Old Nov 7, 2007 | 10:37 AM
Bakeoff's Avatar
If it's aligned properly, suspension bushings, wheel bearings, tires balanced and ball joints are in good shape, you're looking at an axle issue. Tends to be pretty common on the H swaps.
Since you're a newb, I'll go easy, but this should really be in the hybrid section. Not suspension.
Old Nov 7, 2007 | 12:13 PM
ED8dohcZC's Avatar
Default Re: (Bakeoff)
+1
Mfoehrkolb
Sep 21, 2012 09:22 PM
ESCO-->
May 31, 2012 02:11 PM
DRoszyk
Oct 26, 2010 02:42 PM
ScottEK
Aug 23, 2006 04:58 AM
slamed93si
Oct 23, 2003 10:44 AM
