VTEC SOUND!!!!!HELP
Old Nov 6, 2007 | 05:58 PM
illicit_kustomz's Avatar
Default VTEC SOUND!!!!!HELP
I have a H22 swaped integra and when vtec kicks in I hear this rattling sound coming from under the hood. It's a constant sound only when in vtec. Never had this problem before. Can anyone help..
Old Nov 6, 2007 | 11:34 PM
Fezzie's Avatar
Default Re: VTEC SOUND!!!!!HELP (illicit_kustomz)
take the valve cover off and look for unusal wear, get the valve specs and check the valve lash. check out the rocker arms.
Old Nov 7, 2007 | 02:18 PM
slkleltlclh's Avatar
Default Re: VTEC SOUND!!!!!HELP (Fezzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">take the valve cover off and look for unusal wear, get the valve specs and check the valve lash. check out the rocker arms.</TD></TR></TABLE>
Old Nov 7, 2007 | 11:14 PM
tpot90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicit_kustomz &raquo;</TD></TR><TR><TD CLASS="quote">I have a H22 swaped integra and when vtec kicks in I hear this rattling sound coming from under the hood. It's a constant sound only when in vtec. Never had this problem before. Can anyone help..</TD></TR></TABLE>
What do you mean by "When VTEC kicks in,"?
VTEC is always in effect by the ECU.
Old Nov 8, 2007 | 04:40 AM
91DA9's Avatar
Default Re: VTEC SOUND!!!!!HELP (tpot90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpot90 &raquo;</TD></TR><TR><TD CLASS="quote">
VTEC is always in effect by the ECU. </TD></TR></TABLE>
You might want to read up more on how VTEC works. It is not "always in effect" in the ECU, that is why people call it a crossover. Also, there are mechanical changes to the valvetrain when this crossover occurs. I would do what Fezzie suggests first and then probably check the oil level, and if possible, pressure.
Old Nov 8, 2007 | 12:10 PM
Thanks guy's!!!!
vteckyle
29
Nov 8, 2006 06:15 AM
JDMB18CEJ1
Jul 28, 2004 07:30 PM
sleeperb16a
Jun 20, 2004 08:54 PM
LSTEG96
Apr 15, 2004 07:48 PM
Seye
Nov 12, 2003 03:11 AM
