tranny help
Old Nov 6, 2007 | 05:38 PM
LSTEG98's Avatar
Default tranny help
Whats up h-t? Yea, so the other night I was on the highway coming home and 5th gear felt weird when I put it in 5th around 55+mph. I wouldnt call it a grind because its deff not but it feels weird like a grind lol. But its kinda like it hesitates to go in then it does, but it like knocks when going in. I can get it in fine around 50 and under mph, but could it be that my syncros are bad/ going bad? need help dont know if its time for a new tranny or not. thanks
Old Nov 6, 2007 | 11:36 PM
Fezzie's Avatar
Default Re: tranny help (LSTEG98)
something in there is probably going bad, an im sure its gunna do it for a while until 5th gear goes out
Old Nov 7, 2007 | 03:46 AM
LSTEG98's Avatar
up for more info
Old Nov 7, 2007 | 02:17 PM
slkleltlclh's Avatar
Default Re: (LSTEG98)
before jumping to conclusions..try replacing the tranny fluid with genuine honda MTF. if it doesnt get better from there, then yeah its probably wear and tear
Old Nov 7, 2007 | 06:16 PM
b18c1ej8's Avatar
Default Re: (slkleltlclh)
yeah liek Fezzie said i went through about 5 rebuilds in a matter of 3 months and that cant get any better i mean changing the fluid is a temporary fix but eventually that stifness turns into a grind the grind turns into a pop out and that pop out eventually becomes a missing gear on ur shift pattern soon, the best fluid for worn parts is supposedley gm synchromesh although i havent tried it myself
PNK SLP
Transmission & Drivetrain
Sep 20, 2009 01:50 PM
grey_ls_nuka
Oct 10, 2005 09:17 PM
1.8
23
Oct 3, 2004 03:32 PM
cdubracer
Feb 25, 2004 09:46 PM
crxtreme27
Aug 19, 2002 02:11 PM
