Squeky Clutch Cylinder fix?
Old Nov 6, 2007 | 10:56 AM
accord99power's Avatar
Default Squeky Clutch Cylinder fix?
Everytime i press the clutch pedal down i hear the squeky sound, does anyone know of a fix besides replacing?
Old Nov 6, 2007 | 01:34 PM
Chiovnidca's Avatar
Default Re: Squeky Clutch Cylinder fix? (accord99power)
Where is the squeak coming from?
Old Nov 6, 2007 | 02:40 PM
Tyte-S's Avatar
Default Re: Squeky Clutch Cylinder fix? (Chiovnidca)
My 6th gen does the same thing. I don't think anything needs to be fixed or replaced, because it's done it as long as I can remember.
Old Nov 6, 2007 | 02:47 PM
shortlid's Avatar
Default Re: Squeky Clutch Cylinder fix? (Tyte-S)
Look in FAQ there is a TSB (Technical Service Buliten) on this issue with 6th gens. The only fix is a replacement of the master cyl. with a metal one instead of teh plastic one in the car OE. Sucks I know
Old Nov 6, 2007 | 03:04 PM
Chiovnidca's Avatar
Default Re: Squeky Clutch Cylinder fix? (shortlid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid &raquo;</TD></TR><TR><TD CLASS="quote">Look in FAQ there is a TSB (Technical Service Buliten) on this issue with 6th gens. The only fix is a replacement of the master cyl. with a metal one instead of teh plastic one in the car OE. Sucks I know </TD></TR></TABLE>
Depends on where the noise is coming from. If the squeak is coming from the clutch fork a new master isn't going to help much. I agree with you though, probably what it is.
Old Nov 6, 2007 | 03:06 PM
ahhh man another reason to ! i looked at some posts and looks pretty easy to replace, thanks for the advice
Old Nov 6, 2007 | 03:12 PM
Chiovnidca's Avatar
Replace the slave also.
no i almost positive its from the master cylinder i can feel it in the pedal but all get another person to listen to make sure its not coming from the fork.
Old Nov 6, 2007 | 03:17 PM
yah its been needing to be replaced, the threads are striped out alittle from this pos shop that replace my clutch and messed the threads up when bleeding didnt know till i went to bleed it, i have it down to this one spot and if i turn it in either direction a **** hair more it will bleed out when pressin the pedel. but its been like that for several months
Old Nov 6, 2007 | 03:47 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">no i almost positive its from the master cylinder i can feel it in the pedal but all get another person to listen to make sure its not coming from the fork.</TD></TR></TABLE>
What i mean is if you replace one you should replace the other. It saves a lot of time in the long run.
Old Nov 6, 2007 | 05:16 PM
radiuslight's Avatar
When I bought my 93 accord lx
I would press the clutch and it would squeak
I replaced the whole clutch and bearing and it stopped
wardseg6
Feb 15, 2007 01:42 PM
mugenspoongsr
Jul 6, 2006 07:20 PM
NeWnMpR0VeD
Jun 17, 2006 11:46 AM
hip_hop_s0ulchild
Oct 22, 2005 01:35 PM
K20DC2R
Jan 12, 2004 11:55 AM
