cruise control removal
Old Nov 6, 2007 | 10:25 AM
GSRpoweredSI's Avatar
Default cruise control removal
my cruise control doesnt work anyways so i was wondering what i need to do to removie the assembly next to the driver side motor mount. looked for DIY and searched. found nothing. anything will help and will removing it affect anything? Its in a 98 civic coupe with 2000 gsr. thanks
Old Nov 6, 2007 | 10:42 AM
Elevorett's Avatar
well I removed mine as well.
Removing the assembly is the easy part, all you need to do is unplug it and unbolt the black box and pull it out. I just cut the throttle cable.
Old Nov 7, 2007 | 02:23 AM
Default Re: (Elevorett)
mines not the black box, it has a few little hoses that come off it with the throttle cable. would i need to pull a fuse? thanks for your help.
Old Nov 7, 2007 | 08:21 AM
okay i pulled out the assembly, now how do i disconnect the cable going into the firewall and what do i do with the little hoses that go to the intake mani. i just stuff a screw in the end of it. will i get any CEL codes?
Old Nov 7, 2007 | 08:35 AM
burgandybeast's Avatar
Default Re: (GSRpoweredSI)
mine is removed i just tucked the cable down behind intake mani
id like to remove it from the firewall any help on this much needy!
Old Nov 7, 2007 | 08:38 PM
Default Re: (burgandybeast)
Has a cel popped up after you had removed and did you notice anything different?
aaronfunstuff
Feb 9, 2014 08:45 AM
turboman
Nov 16, 2005 09:26 PM
dayaftertomorrow
11
Aug 30, 2005 05:55 AM
Grimm
Dec 1, 2003 05:41 AM
Greyout
Apr 16, 2002 10:02 PM
