how to angle my lioght?
there should be adjusting screws on the back.
1 for up/down, 1 for left/right.
make sure you're on level ground when you adjust!
blinding oncoming cars is not cool...
yup... there should be a slot perpendicular to the "teeth" which will fit a phillip's head screwdriver to turn the screw... and there should be two of these screws (may take a careful eye to spot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i »</TD></TR><TR><TD CLASS="quote">sorry but would you mind taking a pic and pointing it out?? think it would be alot easier.</TD></TR></TABLE>
this if for 94-01 integra...
notice the screw at the top-left and the bottom-middle:
top-left screw up close:
bottom-middle screw up close:
you see what i mean by the "slot" where your screwdriver goes???
ROFL. im trying to get my headlights out but then my abs is in the way and the 94-97 headlights are different. its all encaved and theres a tiny hold on the bottom.....which means i have to take out the whole headlight and my abs. thats freakin gay as hell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i »</TD></TR><TR><TD CLASS="quote">ROFL. im trying to get my headlights out but then my abs is in the way and the 94-97 headlights are different. its all encaved and theres a tiny hold on the bottom.....which means i have to take out the whole headlight and my abs. thats freakin gay as hell.</TD></TR></TABLE>
it's unlike honda to have engineered it to be that difficult. plus, having to take the headlights out to try and aim them doesn't seem right... are you sure you're doing it right?
94-97 headlights do not have the hex head on the adjusting screw. Notice how the adjusting screw has toothed edges. It's like a gear wheel, and you're supposed to use a large phillips-head screwdriver to turn them.
Notice in the pics above there are guides near the adjusting screws. You stick your screwdriver in between those and then turn. It take many turns to make the lights move very much, so a power drill with a long phillips bit in it might be easier.
To reach the outer right/left adjustment, you go in from directly above through a hole in the radiator support.
To reach the up/down adjustment (lower center part of the housing) you have to go in at an angle behind the high beam bulb to get the screwdriver between the guides and onto the gear wheel adjuster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boidc24dr »</TD></TR><TR><TD CLASS="quote">how do i angle my light so they are higer becasue mine a pionting to the ground plz help</TD></TR></TABLE>
depends on ur make & model + year.
patrickstar
Feb 6, 2009 10:33 PM
