Lighting HID/Xenon kits, Retrofits and Associated Topics
how to angle my lioght?
Old Nov 6, 2007 | 06:07 AM
boidc24dr's Avatar
Default how to angle my lioght?
how do i angle my light so they are higer becasue mine a pionting to the ground plz help
Old Nov 6, 2007 | 11:18 AM
pgpunkguy's Avatar
Default Re: how to angle my lioght? (boidc24dr)
there should be adjusting screws on the back.
1 for up/down, 1 for left/right.
make sure you're on level ground when you adjust!
blinding oncoming cars is not cool...
Old Nov 9, 2007 | 02:23 PM
biglou954's Avatar
Default Re: how to angle my lioght? (pgpunkguy)
yea there should be a screw to adjust them!
Old Nov 14, 2007 | 09:50 AM
d0ugch0i's Avatar
what do you mean by a screw to adjust them up and down in the back?? is this for integra too? 1995
Old Nov 14, 2007 | 10:43 AM
pgpunkguy's Avatar
Default Re: (d0ugch0i)
normally there are two screws on the back of the headlight housing.
one screw adjusts vertically (up/down), one adjust horizontally (left/right).
Old Nov 14, 2007 | 11:07 PM
d0ugch0i's Avatar
are the screws the things that look like a circle with teeth on the outside.
Old Nov 15, 2007 | 04:21 AM
pgpunkguy's Avatar
yup... there should be a slot perpendicular to the "teeth" which will fit a phillip's head screwdriver to turn the screw... and there should be two of these screws (may take a careful eye to spot)
Old Nov 15, 2007 | 08:04 AM
d0ugch0i's Avatar
sorry but would you mind taking a pic and pointing it out?? think it would be alot easier.
Old Nov 15, 2007 | 09:29 AM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i &raquo;</TD></TR><TR><TD CLASS="quote">sorry but would you mind taking a pic and pointing it out?? think it would be alot easier.</TD></TR></TABLE>
this if for 94-01 integra...
notice the screw at the top-left and the bottom-middle:
top-left screw up close:
bottom-middle screw up close:
you see what i mean by the "slot" where your screwdriver goes???
Old Nov 15, 2007 | 03:59 PM
d0ugch0i's Avatar
oooo ok. thanks sooo much. i appreciate your time taking the pics and such. your a good man
Old Nov 15, 2007 | 05:14 PM
pgpunkguy's Avatar
no problem, but the pics i actually found online... lol!
Old Nov 16, 2007 | 07:37 AM
d0ugch0i's Avatar
ROFL. im trying to get my headlights out but then my abs is in the way and the 94-97 headlights are different. its all encaved and theres a tiny hold on the bottom.....which means i have to take out the whole headlight and my abs. thats freakin gay as hell.
Old Nov 16, 2007 | 08:03 AM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d0ugch0i &raquo;</TD></TR><TR><TD CLASS="quote">ROFL. im trying to get my headlights out but then my abs is in the way and the 94-97 headlights are different. its all encaved and theres a tiny hold on the bottom.....which means i have to take out the whole headlight and my abs. thats freakin gay as hell.</TD></TR></TABLE>
it's unlike honda to have engineered it to be that difficult. plus, having to take the headlights out to try and aim them doesn't seem right... are you sure you're doing it right?
Old Nov 16, 2007 | 11:39 AM
d0ugch0i's Avatar
yea im pretty sure im doing it right. lolz. ill try taking a picture and you'll see how impossible it is to stick anything in there.
Old Nov 19, 2007 | 05:53 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
94-97 headlights do not have the hex head on the adjusting screw. Notice how the adjusting screw has toothed edges. It's like a gear wheel, and you're supposed to use a large phillips-head screwdriver to turn them.
Notice in the pics above there are guides near the adjusting screws. You stick your screwdriver in between those and then turn. It take many turns to make the lights move very much, so a power drill with a long phillips bit in it might be easier.
To reach the outer right/left adjustment, you go in from directly above through a hole in the radiator support.
To reach the up/down adjustment (lower center part of the housing) you have to go in at an angle behind the high beam bulb to get the screwdriver between the guides and onto the gear wheel adjuster.
Old Nov 19, 2007 | 08:34 AM
fongyz22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boidc24dr &raquo;</TD></TR><TR><TD CLASS="quote">how do i angle my light so they are higer becasue mine a pionting to the ground plz help</TD></TR></TABLE>
depends on ur make & model + year.
patrickstar
Feb 6, 2009 10:33 PM
EFresh
Feb 14, 2006 07:42 PM
EnKidu
Dec 5, 2004 06:58 PM
acuraLSSE95
Sep 15, 2003 10:18 AM
ih8danoles
Apr 21, 2003 12:21 PM
