headlight adjustment
Old Sep 14, 2003 | 06:43 PM
acuraLSSE95's Avatar
New User
Default headlight adjustment
I want to collect some info before adjusting my headlights on my 95 integra. For Vertical aim adjustment, Is it just turning it CLOCKWISE with a philips screw for UPward aiming? Does it apply for both L and R headlight? or turning the L side is opposite of turning for the right side?
Old Sep 14, 2003 | 07:02 PM
Train's Avatar
Default Re: headlight adjustment (acuraLSSE95)
i would also like to know. i do know that each set of lights (left and right) are seperate. i'm pretty sure.
Old Sep 14, 2003 | 07:03 PM
SuzukaBlueAP2's Avatar
Default Re: headlight adjustment (Train)
yeah, all it is is turning that screw. There is one for each light. High beam and low beam are separate. but i'm not sure what direction you have to turn it. Just try it and find out
Old Sep 14, 2003 | 07:50 PM
Deluzional's Avatar
Default Re: headlight adjustment (urbanracer98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, all it is is turning that screw. Just try it and find out
I wouldn't recommend that information to anyone, it takes about 10-15 mins with a regular philips to even realize any difference with the adjustments. Even I dont remember exactly the directions you turn it, but its been posted awhile back.
Old Sep 14, 2003 | 09:11 PM
Train's Avatar
Default Re: headlight adjustment (Deluzional)
yeah, i tried to adjust them for like 10 minutes and it barely moved. and i didn't know what direction to turn it in the first place. i think i made it worse instead of better. anyone know which direction to turn the screws?
Old Sep 14, 2003 | 10:27 PM
xx dc2teg xx's Avatar
i have hids and when adjusting it i did trial and error and i noticed enough difference to know which way to turn
Old Sep 15, 2003 | 09:39 AM
New User
Default Re: (xx dc2teg xx)
Update on the turning direction. My friend had a little problem with his drivers side headlight aiming too low. He raised the VERTICAL AIM UPWARD on the LEFT side by turning it CLOCKWISE, 15+ turns with the philips screwdriver. AS for the RIGHT side, he didn't make adjustment. Can someone verify the turn direction on the RIGHT side? Is it the same going clockwise or vise versa?
thanks
Old Sep 15, 2003 | 10:18 AM
DOHCon15s's Avatar
Default Re: (acuraLSSE95)
yeah when i lowerd my car the headligths point at the ground and where are the screwdriver holes (i havnt looked for them yet ill do it when i get home)
em96civicex
May 24, 2007 04:11 PM
PleaseHelp
Aug 18, 2005 08:20 PM
xcom
Mar 3, 2004 05:10 PM
AWDxBOOST
Nov 25, 2003 07:05 PM
