distributor sensor question about signals
Old Nov 6, 2007 | 04:21 AM
alexsracing's Avatar
Default distributor sensor question about signals
on the distributor does it always give tdc and ckp signals to the ecu or is it only durring cranking of the motor?
B14-TDC M TDC -M Wht/Blue, TDC sensor signal
B16-CKP M CKP -M Blu/yel, CKP Sensor signal
because im only getting a voltage during cranking and zero volts once on then the motor turns off
Old Nov 6, 2007 | 04:56 AM
B16B_coupe's Avatar
HRD PKR
Default Re: distributor sensor question about signals (alexsracing)
well it should get volts while cranking and runnin, not when its shut off..
Old Nov 6, 2007 | 05:39 AM
no the engine will shut off unless I floor it then it just sounds like a 1 cylinder and rpm under 1000. durring the running period it has zero volts, but when I was cranking it there was volts.
if I let off of the gas it will die.
Old Nov 6, 2007 | 06:04 AM
mgags7's Avatar
You have a different problem.
Those are hall effect sensors, voltage will only be induced while the engine is running, and it will be a special AC waveform. What are you looking for there?
Old Nov 6, 2007 | 06:52 AM
trying to determine if my distributor is bad, its a new unit from distributor king.
I have already tryed 2 different ecu's one with my hondata s300, and one with uberdata.
I have tryed stock map sensor, motorola 2.5bar, and an aem 3.5bar, all give the correct voltage
I have tryed 2 different tps's, both with correct voltage
the car ran perfect for 2 days, now won't stay on
Old Nov 6, 2007 | 07:06 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (alexsracing)
they should have .5 when its running...
Modified by B16B_coupe at 8:35 AM 11/6/2007
Old Nov 6, 2007 | 07:11 AM
mgags7's Avatar
Default Re: (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">they should have .5 volts when its running... </TD></TR></TABLE>
They don't output a DC voltage dude, that won't be consistent.
OP: Did you change anything right before it stopped working or did it just happen out of the blue?
Have you pulled all the plugs and checked for spark at all 4? Have you checked the timing belt? Have you checked the firing order?
Old Nov 6, 2007 | 07:16 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Have you pulled all the plugs and checked for spark at all 4? Have you checked the timing belt? Have you checked the firing order?</TD></TR></TABLE>
try a different dizzy then, and how dont they have volts??
Old Nov 6, 2007 | 07:23 AM
mgags7's Avatar
try a different dizzy then, and how dont they have volts??</TD></TR></TABLE>
Oh lordy.
Volts are not specific to DC or AC circuits. Those sensors output an AC waveform, the DC value you get will be somewhat of a mean.
Read up on electronics a bit if you wish.
Old Nov 6, 2007 | 07:53 AM
just happened out of the blue, I tryed 2 sets of new plugs, the firing order is the same as when it was running, the timming belt is perfetly on and new.
only problem is there arn't very many b-series to borrow stuff from around where I live. we don't even have an acura dealership
Im just checking sensors with a multimeter.
Old Nov 6, 2007 | 07:59 AM
B16B_coupe's Avatar
HRD PKR
i didnt mean volts... but thats just what i typed...
Old Nov 6, 2007 | 01:12 PM
bump
Old Nov 7, 2007 | 07:10 AM
ttt
Old Nov 7, 2007 | 08:02 AM
Relic1's Avatar
check for 12V at the injectors (yellow/black wire)
if it goes away your main relay needs attention
connect a timing light, let it sit in your lap with it on, start the car. If the light turns off as the car dies the you're after an ignition problem, if it keeps flashing till the engine stops spinning then it's fuel, compression or spark timing.
Old Nov 7, 2007 | 12:49 PM
there is 12v power at the injectors and signal voltage to each of the rc1000 cc injectors, I have 2 main relays the current being new.
It is running solely on number 4
I can pull plug wire 1,2,3 and it will stay on the same with the gas floored , but will not start if 4 is pulled and 1,2,3 left on.
compression is 185 accross.
1,2,3,4 wire have spark when cranking and running as tested with a plug on wire out of motor
could a bad altenator cause this? what is the difinitive way to test a distributor.
the main relay can't cut fuel on my setup I have a aeromotive a1000 on a switched source with 40 psi pressure in the rail.
Old Nov 7, 2007 | 02:07 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">there is 12v power at the injectors and signal voltage to each of the rc1000 cc injectors, I have 2 main relays the current being new.
with that, there is little that is individual for each cylinder.
plugs, wires, cap and injectors
aftermarket ignition system? (logically yes since you have 1000cc injectors you're aiming that big)
some parts stores offer the ability to test ignitors and coils. (autozone does for sure) but not the other things in the distributor.
without a o-scope it's difficult to test the distributor sensors, trying another distributor is always the easiest way to go there. If the car runs at all, even on one cylinder, the ECU should set a fault for a bad sensor in the distributor.
I highly doubt it's the alternator, it's only job is to charge the battery.
Old Nov 7, 2007 | 04:01 PM
mgags7's Avatar
If you're getting spark to all 4 plugs, fuel to all 4 cylinders, and compression, timing is wrong.
Old Nov 7, 2007 | 04:35 PM
the belt is correct, the timming if correct on hondata s300. I even flashed to stock program adjusted for the 1000cc's
Old Nov 8, 2007 | 05:43 AM
need to get this fixed to prepare for the san antonio IFO in dec
Modified by alexsracing at 9:06 AM 11/8/2007
Old Nov 20, 2007 | 10:17 AM
update I bought a 94 integra gsr, so I took off the dizzy and tryed it , same result, next ill try another set of injectors
SIDreamer
May 2, 2011 09:51 AM
carnage601
Sep 25, 2007 01:57 PM
Gamble-Did-it
May 30, 2004 06:42 PM
tpr
May 14, 2003 11:03 AM
