identifying vtec cams?
Old Nov 5, 2007 | 09:50 PM
wed3k's Avatar
Default identifying vtec cams?
so a box of honda goodies was given to me and these cams that came in it have no serial number or any type of indication. it doesnt seem like they have been run at all and they do have three lobes which lead me to believe they are for vtec.
i was going to put it on a lathe with a dial indicator to measure the lift but whatever.
any ideas? i can get measurements if that works.
Old Nov 6, 2007 | 06:05 AM
mgags7's Avatar
It might help if you post a bit more of the info on them, like where they came from, etc. Is the distributor notch on the exhaust or intake cam..stuff like that....
Old Nov 6, 2007 | 07:36 AM
wed3k's Avatar
well...they were given to me. i found the box in the shop and they said i could take it.
it would be nice if i could find the cylinder head as well.
Old Nov 6, 2007 | 04:40 PM
wed3k's Avatar
dizzy is on intake cam...if that helps.
Old Nov 6, 2007 | 05:03 PM
ekb16's Avatar
Default Re: (wed3k)
this should help..go to camshaft tech
http://www.ff-squad.com/technet/
Old Nov 9, 2007 | 10:26 AM
wed3k's Avatar
there is a stamp on the cams "C" but nothing else...
Crane cams? Crower? Comp cams?
didnt match any of the B series cams in the link specified above.
so many
Old Nov 9, 2007 | 11:26 AM
mgags7's Avatar
Look again dude, with the dist on the intake cam it can't be H, so it is most likely B stuff.
How are you sure of which is the intake cam?
Old Nov 9, 2007 | 02:38 PM
wed3k's Avatar
it was marked that way...
Old Nov 19, 2007 | 05:25 PM
wed3k's Avatar
fits in a P72 head that we have at school, so a set of GSR cams? looks stock though.
do stock cams have a stamp "C" on them? on a set of H23 cams, they have PT2 stamped on them
Old Nov 20, 2007 | 08:03 AM
all-mtr-teg's Avatar
Default Re: (wed3k)
just cause it fits in a gsr head doesn't mean they are gsr cams, itr cams will also fit in a gsr head, so will b16 cams.
Old Nov 21, 2007 | 10:00 AM
wed3k's Avatar
right on, still need to find out what they are now. yay!
TopEndTuner
Aug 16, 2008 11:28 AM
zamrioo2
May 17, 2007 09:03 AM
Tchleung
Jul 19, 2004 03:57 PM
lilcasino
Aug 22, 2003 09:42 AM
