will 310 rc injectors do the job....?
Old Jun 23, 2002 | 09:27 AM
HybridCoupe's Avatar
Default will 310 rc injectors do the job....?
I am running a 95 ls with a drag 3 turbo kit....i am trying to get my car tuned to 10psi will the 310s hold up with that psi and a 255 fuel pump?
Old Jun 23, 2002 | 10:20 AM
Sonny's Avatar
Default Re: will 310 rc injectors do the job....? (HybridCoupe)
I doubt. Stock injectors require a 12:1 disk. 10 psi with stock injectors will result in the FMU adding (12 x 10 psi) = 120 psi to your static pressure (usually about 40 psi). Total = 160 psi. Noooo way.
310's are about 25% larger than stock. An 8:1 is a little small, so you'd probably need a 10:1 disk. That would be (10 x 10 psi) = 100 psi plus your static pressure (40 psi). Total = 140 psi. Definitely still too much.
If you get 370cc injectors, you can run an 8:1 disk and your max fuel pressure will be about 120 psi.
I wouldn't boost more than 6 psi if you're gonna use 310cc injectors.
Sonny
Old Jun 23, 2002 | 11:35 AM
HybridKOOP's Avatar
Screenames gotta go...
I've been around for 4 years with this name, have you not heard of it before?
Old Jun 23, 2002 | 11:39 AM
Ri5e's Avatar
Default Re: will 310 rc injectors do the job....? (HybridKOOP)
Use at least 370 ccs. Thats what I have powering my B20 Turbo @ 10.15 LBs.
Old Jun 23, 2002 | 12:47 PM
who the hell are you I didnt ask for your coment on my screen name! If you woulda spelled it right when you got it you probly wouldnt be havin this problem now would you?
Old Jun 23, 2002 | 12:54 PM
Aeka GSR's Avatar
New User
a little bitter are we?
edit: does anyone have any good links on how the injectors, regulator, and pump all work together? I hear all these fuel/air numbers and I just get confused. And what are normal PSI numbers in each section for a honda engine?
[Modified by Aeka GSR, 2:02 PM 6/23/2002]
Old Jun 23, 2002 | 01:25 PM
SIK IN DA HED's Avatar
New User
LOL
since youre going run that high of boost... get the 310s and 10:1... but i think youre better off gettin Hondata.
Old Jun 23, 2002 | 03:40 PM
Default Re: will 310 rc injectors do the job....? (dlplayboy)
well i have safc and a 255 fuel pump...i was just wonderin if i should get 310s or 370s?
Old Jun 23, 2002 | 03:54 PM
AVATAR's Avatar
I'm maxing out my 370s right now on 12psi w/ a walbro pump. . . if that helps
Old Jun 23, 2002 | 05:56 PM
Default Re: will 310 rc injectors do the job....? (AVATAR)
thanks so basically go with 370s and keep it around 10...
Old Jun 23, 2002 | 06:11 PM
Sonny's Avatar
Which Walbro pump do you have? The GSS317 or the GSS342? They are both "255 lph" pumps. The GSS317 is sold as a "255 lph" pump and the GSS342 is sold as a "255 lph HO" (high output) pump.
Sonny
Old Jun 23, 2002 | 07:51 PM
Liltrix's Avatar
Yes at 10 PSI 310cc can. Stock Injectors have supported 10 PSI over and over without a problem. Taking it much higher than that without proper tuning is not a good idea though.
Old Jun 23, 2002 | 08:00 PM
ekb18c's Avatar
Default Re: will 310 rc injectors do the job....? (Liltrix)
Agreed!!
Old Jun 23, 2002 | 10:33 PM
TurboInteg95's Avatar
Default Re: will 310 rc injectors do the job....? (ekb18c)
I ran my LS turbo with 310s and an 8:1 FMU with a Bosch inline fuel pump for over a year on 10 psi.
Old Jun 23, 2002 | 10:42 PM
Ri5e's Avatar
Default Re: will 310 rc injectors do the job....? (TurboInteg95)
Oh yeah, stock injectors (240ccs) CAN hold up to 12 lbs. But you know, you'll start smelling fuel/fuel leaks.
Old Jun 23, 2002 | 11:35 PM
PureTeg420's Avatar
I too, ran 10psi with 310's, an 8:1 disk, and bosch pump for a year with no problems. However, recently I cracked a ring land ...but that was not fuel related.
Old Jun 24, 2002 | 12:27 AM
shadowdawn's Avatar
Default Re: will 310 rc injectors do the job....? (PureTeg420)
Then what was it related to?
Old Jun 24, 2002 | 01:35 AM
New User
Default Re: will 310 rc injectors do the job....? (shadowdawn)
i have a technical question here about the stock injectors+12:1 fmu VS. 310cc injectors+8:1
how do you figure out will be the better combo? which runs richer than the other? theres always this debate about which rate to use with the 310s. 8:1 OR 10:1. i would opt for the 8:1 fmu rate... but how do we calculate the benefit of using one or the other in terms of scientific calculations. did that make sense? hehe
Old Jun 24, 2002 | 02:09 AM
PureTeg420's Avatar
stock ecu timing advance and too much aggressive driving within an hour. I was running rich the whole time with 310's and an 8:1 disk.
Old Jun 24, 2002 | 06:39 AM
modvp's Avatar
I've been running 310cc on my B18B turbo for the past month now. My timing is set at 15btdc, i'm using an 8:1 disk with and airtex pump. fuel pressure at 9 psi is approx. 107 psi. with this set up I'm getting more fuel than stock with 12:1 FMU. EGT's are 1350 and when i boost, they drop to 1200-1250. It's rich but safe. I get 35 mpg with my 310cc at highway speed (75mph).
Old Jun 24, 2002 | 06:54 AM
modvp's Avatar
Default Re: will 310 rc injectors do the job....? (modvp)
with 310 cc (8:1) fuel pressure is approx. 115 psi on B18B (at 10psi). At that fuel pressure, 310's will flow 507cc and 240's will flow 457cc but with 155psi fuel pressure (at 10psi). the airtex pump max is at 125psi.
based on cal. the 310's flow more and it's within the limit of the fuel pump. My current setup is 9 psi high boost. Fuel pressure is 105 psi and my injector flow is approx. 490 cc (by calculations).
normal driving i'm at 7 psi, and fuel pressure is approx. 90psi. much better than my old set up (120psi with 240's at 7psi)
[Modified by modvp, 3:56 PM 6/24/2002]
Old Jun 24, 2002 | 12:05 PM
dariusz's Avatar
I run daily 10.5psi and 11.5psi in the track with a JRSC and RC 310 cc/min. The car run fine. My fuel pressure in the fuel railk is 85psi at wot.
I'm making a change to RC 440cc/min to add N2O to the car (to cool the JRSC).
Old Jun 24, 2002 | 08:16 PM
New User
thanks modvp. interesting info there.
Old Jun 25, 2002 | 02:26 PM
modvp's Avatar
No problem...
mitchellP
Oct 7, 2005 06:47 PM
platinum00
May 15, 2004 07:14 PM
GOLDBERG
Apr 13, 2003 05:16 PM
turbod16y7vtec
Jan 7, 2003 11:29 PM
bottlefedb18c1
Jul 1, 2002 11:50 PM
