WHY ???? with pictures
Old Nov 5, 2007 | 05:33 PM
laziebun's Avatar
Default WHY ???? with pictures
here my dyno graph to my car when my motor blew after picking it up. it blew the next day cracking the stock sleeve. But the thing is i drove it four hours home, and it drove fine. But i stop and got mid-grade gas because they ran out of the preimun grade and i was running out so i had to get gas. So the next morning i let the car warm up for like 5 min and drove it for about 5 miles and puch it in first around a corner and BANG white smoke..
Question is what might have made it blow, it was running fine home. cause it be the cheap gas? or that the car wasnt warmed up completly?
Old Nov 5, 2007 | 09:31 PM
civicking99's Avatar
maybe it started to crack during dyno and then from sitting over night and getting so cold and then it warming up and getting hot again did it in the rest of the way
Old Nov 5, 2007 | 09:41 PM
92civicx's Avatar
Default Re: (civicking99)
it can be a number of reasons.
i'm no expert at tuning and dyno's but i think the a/f should be even all the way across but i may be wrong. i'm not sure
what was the setup?
Old Nov 6, 2007 | 04:07 AM
Flashmn's Avatar
Default Re: (92civicx)
I dont know, but looking at that A/F graph, looks tad lean on few places.
Old Nov 6, 2007 | 05:28 AM
Chiovnidca's Avatar
Default Re: WHY ???? with pictures (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote"> i drove it four hours home, and it drove fine. But i stop and got mid-grade gas because they ran out of the preimun grade and i was running out so i had to get gas. So the next morning i let the car warm up for like 5 min and drove it for about 5 miles and puch it in first around a corner and BANG white smoke..
So you had it tuned on premium gas, then you ran it on cheaper fuel. The lower octane probably caused detonation.
I accidentally put cheap gas in my civic after being boosted for 5 years, it blew the ring lands out of it before i knew what happened.
Old Nov 6, 2007 | 06:32 AM
laziebun's Avatar
im thinking it was that, or that i didnt let the car warm up complety
Old Nov 6, 2007 | 07:26 AM
Chiovnidca's Avatar
Default Re: (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">im thinking it was that, or that i didnt let the car warm up complety</TD></TR></TABLE>
I doubt it had anything to do with the engine being cold.
Old Nov 6, 2007 | 09:05 AM
jmm96gsr's Avatar
Default Re: (Chiovnidca)
I would guess the lean spot before 6000 rpms and crappy gas. I'm not a tuner but I did stay in a Holiday Inn Express last night.
Old Nov 6, 2007 | 10:18 AM
laziebun's Avatar
oh yeahis that right, question is did you save 15% like i did when i switch over to Geico??
Old Nov 6, 2007 | 11:13 AM
jmm96gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">oh yeahis that right, question is did you save 15% like i did when i switch over to Geico??</TD></TR></TABLE>LOL, no I did not, but State farm treats me pretty good, you know, like a good neighbor. But, seriously that graph does not look right @ 5800-6000 rpms.
Old Nov 6, 2007 | 01:22 PM
laziebun's Avatar
well is said the cause of that jump is due to POWER of vtec engaging so who knows
Old Nov 8, 2007 | 06:23 PM
paarmyguy365's Avatar
Did they retard the ignition time at all? If they didn't then that could have been the problem. By retarding the ignition time you move away from the detonation threshold. You lose a slight amount of power but that can be compensated by better fuel or an intercooler. Both better fuel and an intercooler allow for more timing without the threat of detonation.
Old Nov 9, 2007 | 09:57 AM
nxvictim's Avatar
by putting the cheaper gas in it after it was tuned with premium will definatley cause a detonation because of the compression ratio if either its boosted or just a jdm motor u should always burn premium if thats wat it was tuned with so i would say the fuell u used sorry for ya loss
Old Nov 9, 2007 | 07:00 PM
laziebun's Avatar
Default Re: WHY ???? with pictures (paarmyguy365)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paarmyguy365 &raquo;</TD></TR><TR><TD CLASS="quote">Did they retard the ignition time at all? If they didn't then that could have been the problem. By retarding the ignition time you move away from the detonation threshold. You lose a slight amount of power but that can be compensated by better fuel or an intercooler. Both better fuel and an intercooler allow for more timing without the threat of detonation.</TD></TR></TABLE>
Well im not sure what he did or if he did, but i do have s300 so i can get the calibration off the Smanager and post it here and see what you guys think. I cant do it yet because im still in the process of putting my motor back together. Once i get it up that will be the first thing i do, two more weeks and we're back in business.
And yeah i feel like a dumb *** to use the cheap gas, should have tryed to push it a little more to another gas station . But what is life with out mistakes right?
EJ_ALLMOTA
Apr 11, 2013 05:47 PM
PYITR678
Mar 20, 2010 03:03 PM
vtechjunkie
Dec 12, 2008 03:14 PM
XstouterX
Dec 18, 2005 07:56 AM
geminis2k
Nov 10, 2003 01:14 PM
