Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
key stuck in the ignition!!
Old Nov 5, 2007 | 07:46 AM
mickyT's Avatar
Default key stuck in the ignition!!
okay...my granparents have a honda pilot...and their key is stuck in the ignition...and there is no way of taking it out...is there anyway of taking it out??
Old Nov 5, 2007 | 09:07 AM
CfnRyan's Avatar
Default Re: key stuck in the ignition!! (mickyT)
can u push it in with the key in the off position?
mike
Old Nov 5, 2007 | 11:50 AM
mickyT's Avatar
Default Re: key stuck in the ignition!! (CfnRyan)
no we can not...
Old Nov 5, 2007 | 03:47 PM
mickyT's Avatar
Default Re: (Evil M0nkey)
its in park...it been like this for a while now...about a month or two...we have tried everything....park, neutral, pushing into the ignition....we were thinking about using WD-40...but we know if that will mess up the ignition....so we don't know wat to do? anyone??
Old Nov 6, 2007 | 04:49 AM
Shiftyshadee's Avatar
Default Re: (mickyT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickyT &raquo;</TD></TR><TR><TD CLASS="quote">its in park...it been like this for a while now...about a month or two...we have tried everything....park, neutral, pushing into the ignition....we were thinking about using WD-40...but we know if that will mess up the ignition....so we don't know wat to do? anyone??</TD></TR></TABLE>
Is the steering wheel turned in the lock position? That can cause the key to not come out of the ignition.
Do the brake lights work? Another possible cause is a faulty brake switch. If the switch is bad the vehicle won't recognize that it is in park and will lock the key in the ignition.
Modified by Shiftyshadee at 8:50 AM 11/6/2007
Old Nov 6, 2007 | 10:36 AM
mickyT's Avatar
Default Re: (Shiftyshadee)
we have been able to drive the car...and all...but afterwards the key won't come out....
Old Nov 6, 2007 | 10:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shiftyshadee &raquo;</TD></TR><TR><TD CLASS="quote">Do the brake lights work?</TD></TR></TABLE>
Old Nov 7, 2007 | 10:33 AM
mickyT's Avatar
like i said before...we have been able to dirve the car around for about 2 months now...so the brake lights do work...my grandpa drives this car daily....
Old Nov 8, 2007 | 08:26 PM
PnX-R's Avatar
Hmm.. Here's something you can try.
Move the shifter as far up into Park as you can. Maybe it's out of adjustment. Then you can also try and move your shifter out of Park and back into it. This time listen for a noticeable click. Your ignition lock cylinder should click and release your key. If it's clicking, I would assume it's your Park switch on the shifter assembly.
I'm not sure how it's mounted in there, but in the 01-05 Civics, I've had that little pawl/detent break off and not contact the Park switch. This also causes the shifter to shift past the last gear, in this car it would go past gear 2.
I'd check that. If it's your park switch, disconnecting it should release your key.
Old Nov 10, 2007 | 08:46 PM
ericthegreat's Avatar
I had the same problem with my early 90's Civic and was able to fix it earlier this week. Here's what I did to fix it:
http://www.untangible.com/blog....html
93civicsedan
Honda Civic (2001 - 2005)
May 21, 2008 06:26 PM
blackrag
11
Mar 4, 2007 11:03 PM
VTECdTypS
23
Jan 20, 2005 02:25 PM
Spoolin93si
Jan 18, 2005 07:36 PM
137
Audio / Security / Video
Oct 7, 2004 07:36 AM
