Noisy Transmission after clutch install?
Old Nov 5, 2007 | 04:19 AM
Stoich's Avatar
Default Noisy Transmission after clutch install?
Hey fellas we just swapped in a new clutch/pressure plate/bearing/pilot bearing on to my buddys d16a6 engine
Now the car makes this anoying wuring/rattling noise when the clutch is out. Soon as you press the clutch in it stops.
Any input would be great.
Thanks
Old Nov 5, 2007 | 05:59 AM
90efhatch's Avatar
Default Re: Noisy Transmission after clutch install? (Stoich)
that sounds to me like you got a bad throwout bearing.
Old Nov 5, 2007 | 06:22 AM
JustAnotherRex's Avatar
Default Re: Noisy Transmission after clutch install? (90efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efhatch &raquo;</TD></TR><TR><TD CLASS="quote">that sounds to me like you got a bad throwout bearing.</TD></TR></TABLE>
+1 Sounds like the throwout maybe going out on you.
Old Nov 5, 2007 | 06:25 AM
IT GUY's Avatar
Default Re: Noisy Transmission after clutch install? (JustAnotherRex)
did you grease the TO bearing?
Old Nov 5, 2007 | 06:28 AM
CRX Toad's Avatar
Default Re: Noisy Transmission after clutch install? (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">did you grease the TO bearing?</TD></TR></TABLE>
Old Nov 5, 2007 | 07:33 AM
rd91sib18c5r's Avatar
If the noise goes away with the clutch in it is probably the pilot bearing in the
tranny. Tranny needs rebiuld.
Old Nov 5, 2007 | 08:07 AM
IT GUY's Avatar
Default Re: Noisy Transmission after clutch install? (rd91sib18c5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote">If the noise goes away with the clutch in it is probably the pilot bearing in the
tranny. Tranny needs rebiuld. </TD></TR></TABLE>
pilot bearing isn't in the transmission. It's in the flywheel.
Old Nov 5, 2007 | 10:28 PM
Sorry I mean input shaft bearings, your right the plot bearing is in the
flywheel.
Modified by rd91sib18c5r at 11:41 PM 11/5/2007
Old Nov 6, 2007 | 04:58 AM
IT GUY's Avatar
^^could be. I wonder if the transmission got filled back up all the way.
Old Nov 6, 2007 | 09:11 AM
Stoich's Avatar
We installed a new pilot bearing and new TO bearing.
When you say greased the TO bearing what part are you referring to?
We lubed the shaft that the TO rides on.
Old Nov 6, 2007 | 02:38 PM
Aristotle's Avatar
Not the throwout bearing for sure, but the pilot bearing.
Old Nov 6, 2007 | 04:30 PM
Runnerdown's Avatar
Default Re: (Aristotle)
Bad input shaft bearing. Happens to all the honda manual transmissions.
When a throwout bearing has failed it makes noise when the clutch is depressed, NOT let out.
924doorEG
Aug 27, 2007 02:07 PM
crxmex
Mar 12, 2007 06:30 PM
Baron55
Dec 19, 2006 06:25 PM
cbmprelude
10
Oct 7, 2006 03:12 PM
si_hatch
11
Aug 9, 2005 09:05 AM
