SiR-LSD Third Gear Grind
Old Nov 4, 2007 | 07:50 PM
honda_mike's Avatar
Default SiR-LSD Third Gear Grind
What's up guys, I got an LSD transmission. It's not an aftermarket LSD it is the oem one for the transmission. I am beggining to get a third gear grind. Not when I normally drive it is when I punch it then shift even if it's a low RPM I shift at i still hear it.
What fluid can I use on this transmission to fix that ? and im guessing the fix is just temporary, I don't know if I should be using gm synchromesh on the lsd transmission. I got Honda MTF in it right now. I know im probaply going to have to replace the synchro in this tranny, pricey but, good tranny to keep
Old Nov 5, 2007 | 10:55 AM
honda_mike's Avatar
Anything?
Old Nov 5, 2007 | 07:06 PM
db1_jdm's Avatar
Default Re: (honda_mike)
changing ur fluid is not gonna do anything to fix the problem you have. You gotta rip apart the tranny and inspect/replace ur 3rd gear syncro.
hfrex
May 14, 2009 03:20 PM
ryanj1025
Jan 23, 2008 01:11 PM
White_EK49
Nov 3, 2005 05:08 PM
ELAMINT5
Jul 21, 2004 05:13 PM
blktype-r
Jun 6, 2004 06:02 PM
