M6 x 100 mm bolt
Old Nov 4, 2007 | 07:01 PM
hondatech94's Avatar
Default M6 x 100 mm bolt
Hi, i have a question about a certain bolt that i need to change the balancer belt in my 94 accord. I read somewhere that i need a special tool or a M6 x 100mm bolt.
What does the M6 stand for and what kind of a bolt is this...can someone please explain i plan on doing this sometime this weekend...and i need to know quickly...thanks
Old Nov 4, 2007 | 09:00 PM
pos_cd5's Avatar
Default Re: M6 x 100 mm bolt (hondatech94)
M6 = 6mm dia. the 100 after it probably is specifying the thread pitch which is 1.00. if it indeed does say 100mm than that is the length of the bolt, leaving the thread pitch a mystery. if it is just a standard hex cap M6-1.00 bolt than you wont need nothing special, any socket or wrench should take it off.
Old Nov 4, 2007 | 09:11 PM
Default Re: M6 x 100 mm bolt (pos_cd5)
thanks... i don't need to unscrew this bolt or anything...i need it to keep some pulleys in place when i change my timing belt and balancer...imma use it for like a pin
Old Nov 4, 2007 | 09:29 PM
Hawkze_2.3's Avatar
An M6 is another way of describing the hundreds of bolts on any Honda that use a 10mm socket. The M6 is the thread size, but all the ones on a Honda have a 10mm head, so, for example, you could just take out one of the bolts that hold on your fenders or radiator supports and use one of those.
Old Nov 5, 2007 | 03:55 AM
TouringAccord's Avatar
H-T Order of Merit
like already said, the M6 stands for the thread diameter which is 6 millimeters (mm). The 100 is the length of the bolt in millimeters.
You dont actually NEED and M6x100 for that job. Anything of close size will work just fine. So probably a #1 phillips screwdriver would work, or... Just anything thats about 6mm in diameter and thats atleast 100mm long will work.
Old Nov 5, 2007 | 05:45 AM
jamin's Avatar
Default Re: M6 x 100 mm bolt (TouringAccord)
this bolt-i used a thin rod- is reco'ed to insert into the hole to hold the rear balancer shaft in place while balancer belt is installed. the writeups i have seen suggest marking whatever is-so i did- used to insert into the hole at 74mm-or is it 76?- to insure full insertion when shaft is at its alignment marks.
my timing and balancer belt replacements went well.
i wonder though, what happens if the front and rear balancer shaft pointers were not aligned prior to balancer belt install? has anyone experienced this?
psychotech
Oct 15, 2010 11:56 AM
Schrader
Apr 25, 2006 02:23 PM
BROKE.eg
17
Nov 25, 2005 08:19 PM
seeeya04
Nov 24, 2005 03:25 PM
Renegade
15
Sep 22, 2003 06:28 AM
