What is this part called? and how do I fix this...
Old Nov 4, 2007 | 04:35 PM
br3ak3r84's Avatar
Default What is this part called? and how do I fix this...
I couldn't search for how to fix this problem because I don't know what its called. Bascially, I've had a clutch fluid leak for a while and I replaced both my master and slave clutch cylinders and the hose from the reservoir to the clutch master cylinder. There is still a leak and recently all the fluid leaked out and I was stuck on the freeway with a clutch pedal and stayed down. I looked all throughout the engine bay following the brake lines and found a leak. In the picture is where the leak is located but what is that peice the lines connect into? and how could I fix the leak in this portion??
*sorry about the bad art. I couldn't take a pic becuase it was too dark and all you see is black*
this is for a 96 honda prelude and is a hydraulic clutch.
Old Nov 4, 2007 | 04:37 PM
SteveoBA8's Avatar
Default Re: What is this part called? and how do I fix this... (br3ak3r84)
The clutch dampner assembly.
Old Nov 4, 2007 | 04:50 PM
Hawkze_2.3's Avatar
Search :https://honda-tech.com/zerothread?id=1210919
That's a good diagram BTW.
hannslebo
Mar 24, 2009 01:53 PM
afropuffs808
May 2, 2008 06:17 AM
br3ak3r84
Nov 5, 2007 08:12 PM
DragII
Oct 27, 2004 06:06 AM
