Blown Motor, now what?
So i got a 97 civic hatch dx manual. just blew the motor last week looks like a rod let go or something. big hole in oil pan from what i can see. trying to decide what to do with it.
so what wrong with the car is the blown motor, bad cv joints, will need brakes, clutch, and tires soon as well.
so i guess what i'm asking is should i fix it (stock engine or maybe y8 motor), part it out, sell it as-is, or engine swap it?
if i put in a new engine, i can do the work no problem, just don't have alot of money to put into it ($500 at most prob) and i can drive my mustang untill i get it done.
Where are some good places to get a new motor from? what all do i need to add the y8 vtec motor with minimal issues?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprman »</TD></TR><TR><TD CLASS="quote">So i got a 97 civic hatch dx manual. just blew the motor last week looks like a rod let go or something. big hole in oil pan from what i can see. trying to decide what to do with it.
y8 is a bolt in deal. you'll need to modify wiring. as far as where to buy a y8 from that should easy to find locally. fixing your y7 won't be worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasoncrashtech »</TD></TR><TR><TD CLASS="quote">
y8 is a bolt in deal. you'll need to modify wiring. as far as where to buy a y8 from that should easy to find locally. fixing your y7 won't be worth it. </TD></TR></TABLE>
yeah, what he said
Bad CV joints?
LoL
Yeah, you slung a rod bro, the block = owned.
I'd step it up to a Y8, it's just bolt-in + wiring up for VTEC (adding <5 wires).
EDIT:
Or you can just drop another Y7 in there, as others have said, fixing your Y7 isn't worth it, they're a dime a dozen.
LoL
EDIT:
check around in the market place on here for a y8 or a y7 block. u will find one. i picked one up a few years ago for 200 bucks with nothing wrong with it. lol and then i blew it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprman »</TD></TR><TR><TD CLASS="quote">yeah cv joints are bad, so it needs new axles i guess.
i wonder if i can just get a whole front end from an ex and install it from the bottom up.</TD></TR></TABLE>
that would in no way be cheaper even if you did find one.
JDM_EK_JOE
May 16, 2006 11:32 AM
