obd1 gsr into EK 96 obd2a SWAP HELP ME
95 gsr swap from EG into 96 EK I got the dizzy,alt,injectors converted just fine.
The only prob im haveing is wireing of course...I have the ecu conversion
harness with a obd1 crome chipped p28. Engine harness is the only prob.
So my buddy was in a hurry and needed a engine harness asap.
EX harness was imposable to find so i got a HX AUTOMATIC harness 97 obd2a.
I figured we could make it work and it had Vtec allready.
Ok so theres TONS of plugs on the harness not being used.
1- Theres a huge plug at the end of the harness on the driver
shock tower going to NOTHING and one is pluged in normal.
I looked at my 96 hatch with a gsr and i only have one plug
on that side. So why does this HX harness have TWO ?
2- Theres 3 plugs kinda small there black with a blue thing inside....
What are they ?
3- The front sensor on the 5spd tranny (not speed sensor) Has nothing
to plug into on the harness ? Why is it because of the AUTO harness ?
4- Couple sensors right side behind intake mani ( knock maybe ? crank angle ?)
I wont need those with obd1 will i ?
I havent tryed to start it yet but i was hopeing someone would be able
to help me eliminate some of these loose plugs.
Remember my OBD1 crome ecu shouldent need some obd2 sensors.... but what ones ?
Please help brothers
What are they ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic95hbvtec »</TD></TR><TR><TD CLASS="quote">
on that side. So why does this HX harness have TWO ? power steering
What are they ? my guess is the evap/egr valve
to plug into on the harness ? Why is it because of the AUTO harness ? what do you mean? there is a extra connector on the harness or trans?
I wont need those with obd1 will i ? no, you wont
depends on what ecu, jdm/usdm... you should be fine... but i would of just got a ex harness
Please help brothers</TD></TR></TABLE>
OK so i tryed to start it and got code 16 ? ?
Injectors seem fine... but wont start turns over smooth but seems like its not getting fuel ? THERE IS FUEL TO THE RAIL THOUGH.
Still a HUGE plug not being used on driverside
near strut tower about 8 wires going to it ???
Could be power steering but its BIG with alot
of wires ? very end of the harness 2 plugs one empty... ?
Wish i had a ex harness.......
xkrazyxjbrkerx75
14
Aug 19, 2010 12:47 PM
honda_hackett
Mar 31, 2009 06:03 AM
oneforce
Apr 24, 2006 10:21 AM
