NEED HELP! D16Z6 SWAP INTO A 96 EK CIVIC! WIRING ISSUES!
I have a 96 civic coupe, it has a OBD2A HARNESS. I just put a full swap d16z6 in it, i got a crank angle sensor check engine light code. Im not sure if i should buy the z6 harness yet. I saw the z6 harness and it has different plugs connected to the driver side. My driver side has one plug and the z6 harness has 3 plugs on the driver side. Does anyone have a diagram or a thread where it shows how to convert your car to obd1 using a obd2a dash harness.. PLEASE CAN SOMEONE HELP!
Re: NEED HELP! D16Z6 SWAP INTO A 96 EK CIVIC! WIRING ISSUES!
you cant use the z6 harness. its a 2 part harness that seperates at the shock tower. the 96-98 civic harness is a one piece harness that does not come apart anywhere and runs directly into the cabin and plugs into the ecu.
to convert your car to obd1 you'll need an obd2a to obd1 jumper, and then to convert either your engine harness to accept the obd1 dizzy, or convert the dizzy to work with the obd2a harness plugs. i just did this exact swap on my car and it works fine no problem. this is how i switched the wires from the obd2a engine harness to the obd1 dizzy plugs.
http://www.ff-squad.com/technet/
Hey this site has helped me with wiring issues every time! Goodluck.
thanks for the info man, so u did a d16z6 motor in your obd2a engine harness? I did that and i did the ckf trick, and now i get a CEL CODE #4, crank angle sensor... So all i need to do is to convert my obd1 dizzy to my obd2a harness? how did you fix your crank angle sensor?? i already have a obd2a to obd1 conversion harness with a p28 and i still get the code..
i never had an issue with my crank angle sensor. my car started right up after converting the distributor plugs and plugging in the p28. all i can figure is either you have the wiring wrong or the dizzy is toast.
why did you do the ckf trick? obd1 ecu's don't look for a crankshaft fluctuation sensor..
you did what now? no wires from a wideband should be tied into the ecu harness.. if you have an aem wb for example you'd have a power wire and ground wire, and then 2 outputs. one analog, one rs-232 serial. neither of which the stock ecu can interpret. sooo did you mean narrowband by chance?
ohh ok, cause you hadn't mentioned anything about tuning up till now so i was like wtf lol
that aside, i still don't understand why you need to bypass the ckf. the p28, an obd1 ecu, does not look for it.
yes... i am confused about that.... maybe the car is under my old motor?? in the tuning program? maybe i need to switch it to d16z6? idk man... it could just be the obd2a harness looking for the signal? i have absolutely no idea....or maybe its looking for the ckp sensor because obd1 have it in the dizzys..
obd0,1, and 2 all have the ckp in the dizzy. obd2 is the only one with the ckf. i'm not sure about the tuning software looking for the ckf, but i suppose it could be possible. especially if you're sure that is the code you are getting, and that should not be possible on your current ecu lol.
Technical Hero
You'll have one wire connector for the knock sensor (the Z6 doesn't use it, round plug one wire). Also you'll have one plug by the crank pulley for the (CKF sensor, two wire square plug) because the Z6 doesn't use that either. The Z6 also uses the intake air temp sensor in the intake manifold (round plug, two wire) and the OBD2 SOHC's use it in the intake box or intake arm (two wire square plug) so you'll have to wire up that connector as well. The Z6 also doesn't use a secondary O2 so you can leave that plugged in but you won't use it with the P28 ECU. Finally the Z6 doesn't use the same vacuum emissions sensor (the OBD1 is round) on the fuel rail as the OBD2 SOHC (square plug) so you'll have that left over too. So unless you convert to OBD1 and use the P28 you'll throw some codes.
daredeezy619
11-21-2008 04:38 PM
