Modifying
Right now i have a 2000 honda civic ex jdm b16 swap with short ram intake and greddy sp2 exhust and i was wondering if i want to hook up my car wat is the next thing i should do or if any one can give me step by step things i should do.
There"s no right answer what do you <U>want</U> to do with it? all motor? boost? do you want to eep the B16 or swap it again? its your car and if you build it according to what people tell you to do then you wont be as proud
Personally I like building heads, but before you get too into it figure out if your gonna boost it or not, If your for sure going to boost it build the block for it get a block guard, and some lower compression pistons is a good place to start, also its never a bad idea to get an extra block if you have the money and build it while the current engine is in the car, any b series block will fit your tranny is my impression, so you may even look at the B18 or B20 to build up in the garage, just drop it in all at once. For an all motor build do the normal breathing upgrades (Intake, Header, Exhaust) larger throttle body, better intake manifold, new valvetrain port match the manifolds, higher compression pistons. Just my Noob 2c
the one thin g i notice i my car doesnt pull wen its in gear they told me it mite be my wireing harness casue my sensors went off o2 sensoer knock sensor but do remcomend oullys to i mean i cant even beat a 2007 hhonda civic ex stock it smokes me ?
