car cranks but doesnt fire up
Old Nov 3, 2007 | 01:15 PM
H22TurboNos's Avatar
Default car cranks but doesnt fire up
not sure what happened, came home last night, tried to start today, just keeps cranking but doesnt fire up.
checked a couple things so far, but throw me some suggestions
checked plugs, checked ground, check dist. cap, checked main relay, resoldered it.
so far i tested to see if fuel leaks out when i turn the ignition twice, timing belt is still on, i did notice fuel doesnt leak out, so im thinking it could be the fuel pump that went out
Old Nov 3, 2007 | 01:23 PM
SikB's Avatar
Default Re: car cranks but doesnt fire up (H22TurboNos)
You should be able to hear your fuel pump go on for a couple seconds right after you turn you key on before you crank it. Loosen the banjo bolt on your fuel rail to see if you are getting presure. You need fuel air compression and spark to run an engine. If you can figure out which one you are missing you are halfway home.
Old Nov 3, 2007 | 01:26 PM
reymond23's Avatar
normally when u turn the ignition on before starting you'll hear your fuel pump activite, if it does'nt then i would think it took a carp on u.. hope that helps
Old Nov 3, 2007 | 01:36 PM
Default Re: car cranks but doesnt fire up (reymond23)
yeah im praying its not the fuel pump and something more simple like me not soldering the main relay correctly, i dont hear the fuel pump activate thats the problem. btw im on a walbro 255lph fuel pump
Old Nov 3, 2007 | 01:40 PM
SikB's Avatar
If you aren't getting any fuel check your fuses before you replace the pump.
Old Nov 3, 2007 | 01:53 PM
Default Re: car cranks but doesnt fire up (SikB)
is there a specific fuse i should be checking for? seemed like all of them were still good
Old Nov 3, 2007 | 01:56 PM
UK_Luder's Avatar
Sounds to me like it might be your ignitor or coil, in the distributor. I had the exact same problem a while ago, and they are quite a common thing to go on Ludes.
Old Nov 3, 2007 | 02:08 PM
Default Re: car cranks but doesnt fire up (UK_Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK_Luder &raquo;</TD></TR><TR><TD CLASS="quote">Sounds to me like it might be your ignitor or coil, in the distributor. I had the exact same problem a while ago, and they are quite a common thing to go on Ludes.</TD></TR></TABLE>
hm maybe its my igniter, ill look into this as well
Old Nov 3, 2007 | 07:27 PM
if the main relay is bad will the fuel pump still whine? on intial turn key start?
Old Nov 3, 2007 | 10:29 PM
autoluder's Avatar
both my hondas needed a new distributor, if your cranking all day long, smell unburned fuel, its a great chance is the dizzy. I put a honda dizzy in the lude, and distributor king dizzy in the accord, both are still going strong no problems. A piece of advice - i learned the hard way, if you install the dizzy to the block and it doesnt go in all the way, take it out and turn the shaft 180 degrees
Old Nov 4, 2007 | 04:52 PM
im pretty sure it cant be my ignition, because my fuel pump isnt priming
Old Nov 4, 2007 | 05:24 PM
Acidcrakker's Avatar
Default Re: (H22TurboNos)
Bad fuel pump then. If you turn the key to the ACC postion you should be able to hear the fuel pump prime. If not, well then you found your problem.
Old Nov 4, 2007 | 07:34 PM
are walbro fuel pumps known to go bad that early? i barely had it for a year, roughly like 6k miles
Old Nov 4, 2007 | 10:22 PM
vinuneuro's Avatar
Can you hear the main relay click when you turn on the ignition?
Old Nov 5, 2007 | 03:16 AM
Default Re: car cranks but doesnt fire up (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Can you hear the main relay click when you turn on the ignition?</TD></TR></TABLE>
i cant remember honestly, but is it noticeable?
jerryscherry
13
May 8, 2014 10:08 PM
bimmeracer
Jul 16, 2008 06:12 PM
whitehf
Aug 6, 2006 01:22 PM
terminaloverlowd
Jun 19, 2004 07:01 PM
JolToN49
Nov 20, 2002 11:41 AM
