EG/B series tranny mount (help please)
Old Jun 22, 2002 | 08:24 PM
chirp3rd's Avatar
Default EG/B series tranny mount (help please)
ok i just swap in my B16 in my EG which used 2 be an automatic, i dont know which lower tranny mount 2 use, the auto mount doesnt line up with the B series transmission. which mount can i use and where can i find it
Old Jun 23, 2002 | 11:58 AM
chirp3rd's Avatar
Default Re: EG/B series tranny mount (chirp3rd)
ttt
Old Jun 23, 2002 | 02:24 PM
Slopoke's Avatar
Use an integra mounting bracket and reuse your stock rubber mount.
Just go grab one from a junk yard.
Old Jun 23, 2002 | 02:46 PM
0psi's Avatar
Default Re: EG/B series tranny mount (Slopoke)
The difference between the AT and MT is in the bracket mounted to the chassis. You can get the correct one from the dealer and have it welded in and you should be fine. I don't have too much experience with swapping AT cars while doing a MT swap as well, but I know this way works.
Old Jun 23, 2002 | 05:52 PM
JD_B18CDX's Avatar
I had an auto trans D15 before the swap.
I now have a B18C in the car. So we are kinda in a in the same boat.
U need to unweld the automatic chasis bracket on the passenger side.
Get a manual bracket fromt the junk shop and weld that in place. The integra mounts should bolt right up.
Old Jun 23, 2002 | 07:34 PM
chirp3rd's Avatar
do you any of you know if place racing or Hasport make a mount for this situation
Old Jun 24, 2002 | 06:13 AM
chirp3rd's Avatar
Default Re: EG/B series tranny mount (siblue-sol)
thanks
the soL that could
Aug 21, 2011 07:08 AM
JediKnight4life
Jun 24, 2008 12:28 PM
Dyzee
Mar 16, 2004 12:02 PM
SAVIOVEGA
Oct 30, 2003 05:28 AM
chirp3rd
Jun 23, 2002 11:59 AM
