need help on wiring walbro fuel bump.
Old Nov 3, 2007 | 06:29 AM
RACEPAK's Avatar
Default need help on wiring walbro fuel bump.
sup everyone.
my walbro is currantly wired to the stock relay, and i want towire it with thicker wires like everyone does,
anyone have instructions or can tell me how to do this?
ps, which relay i need?
thanks
Old Nov 3, 2007 | 07:04 AM
LS-V Turbo's Avatar
Default Re: need help on wiring walbro fuel bump. (RACEPAK)
Why rewire the fuel pump circuit. I didn't and not one of my friends have had to rewire theres mine is working just fine putting out 50 psi and im running 1000cc injectors.
Old Nov 3, 2007 | 10:28 AM
RACEPAK's Avatar
Default Re: need help on wiring walbro fuel bump. (LS-V Turbo)
afaik it draws more current then the stock pump,
and most pepole do it that way....
Old Nov 3, 2007 | 10:30 AM
HondamanXxX's Avatar
GO GIANTS!
Bump. I'd like to know also.
Old Nov 3, 2007 | 10:58 AM
LS-V Turbo's Avatar
Default Re: need help on wiring walbro fuel bump. (HondamanXxX)
Well im not sure if your intrested but my friends and i have had no problem with the stock wiring on ours. and im running mine about as hard as you can its supporting about 400whp. Just thought i would let you know, so your not doing more work than is needed
Old Nov 4, 2007 | 01:37 PM
RACEPAK's Avatar
ttt.
i can hear the pump slightly goes up and down when i use my side markers.
Old Nov 4, 2007 | 01:42 PM
egsleepercivic's Avatar
re wire your side markers, you shouldn't have to re wire the fuel pump
Old Nov 9, 2007 | 11:46 AM
RACEPAK's Avatar
ttt
littlecrxVTEC
Dec 26, 2007 02:54 PM
IntegraTypeR
Oct 8, 2006 10:14 AM
wade
Jul 1, 2004 08:47 AM
.ShawnD.
Oct 22, 2002 01:09 PM
yellow blur
Jun 15, 2002 12:54 PM
