VX clutch problems? New to hydro clutches
Old Nov 2, 2007 | 09:26 PM
SiMateoAko's Avatar
Default VX clutch problems? New to hydro clutches
Picking up a VX tomorrow. Test drove it tonight.
This is my first EG... and I've not dealt with hydro clutches before.
I can shift into gears just fine, but the gear doesn't grab until the very top of the pedal. It's rather annoying. The previous owner thinks the clutch is going out, but if that were the case (I'm pretty sure) the clutch wouldn't engage until the pedal was on the floor... not the other way around.
The pedal comes back up, and has regular pressure.... it just won't grab until the very top of the pedal.
Hope this makes sense.
Can anyone offer an idea? The pedals might be after market. Is it possible that i just need to adjust the pedal?
Old Nov 2, 2007 | 09:40 PM
DCSportEJ1Civic's Avatar
Default Re: VX clutch problems? New to hydro clutches (SiMateoAko)
bleed it.
Old Nov 2, 2007 | 10:03 PM
shadohconspiracy's Avatar
it could be the pedal adjustments
Old Nov 2, 2007 | 10:16 PM
SiMateoAko's Avatar
Default Re: VX clutch problems? New to hydro clutches (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">bleed it. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohconspiracy &raquo;</TD></TR><TR><TD CLASS="quote">it could be the pedal adjustments</TD></TR></TABLE>
So you're both in agreement that it most likely isn't the clutch?
Old Nov 2, 2007 | 10:18 PM
does the clutch grab hard or really soft?
Old Nov 2, 2007 | 10:30 PM
SiMateoAko's Avatar
Default Re: (shadohconspiracy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadohconspiracy &raquo;</TD></TR><TR><TD CLASS="quote">does the clutch grab hard or really soft?</TD></TR></TABLE>
It's really difficult to tell... it only grabs at the very end of depressing the pedal. It definitely feels softer than my 07 Fit, but that's to be expected.
Old Nov 3, 2007 | 09:40 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (SiMateoAko)
to confirm it's not the clutch. acclerrate in 1st and then shift to 5th and floor it. if the clutch dossent slip or act like it's trying to slip it's not the clutch giving out
hypertensor25
11
Apr 17, 2007 02:10 PM
axiomjunglist
11
Sep 12, 2006 12:04 PM
meagainsttheworld
Aug 30, 2006 05:53 PM
90hatchie
Nov 10, 2004 12:04 PM
AspectIndustries
Jan 5, 2004 07:49 AM
