Tire Sizes
For those of you with 15" wheels, what size tires are you running on? I'm running on 205/55/15's, but I having some doubt about them. According to the tire calculator (http://www.miata.net/garage/tirecalc.html), I'm only going 59.2 mph when the speedo says 60 mph, with the tires I'm running on
. Just wanna ask around to see if there are better tire sizes to keep the speedo accurate. Thanx.
What would be better to run?
Out of these two:
215/55-16 or 205/55-16
Out of these two:
215/50-16 or 205/50-16
I'm actually leaning towards 215/50-16. I think i'm running 205/50-16.
http://www.miata.net/cgi-bin/tirescgi I used this to compare 185/65-15
Out of these two:
Out of these two:
Naw it won't rub. 7th-gen civics can have a tire width of up to 215mm, and a rim width of 19 inches. So ur safe
Sidewalls, uh, some but not too much, at least better than 15" wheels.
.Sidewalls, uh, some but not too much, at least better than 15" wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut »</TD></TR><TR><TD CLASS="quote">What would be better to run?
Out of these two:
Out of these two:
http://www.miata.net/cgi-bin/tirescgi I used this to compare 185/65-15</TD></TR></TABLE>
I have 215/50/16's on my R/C Starks. Check the picture thread for recent photos. They're identical in height to the stock size, so there's no loss/gain on the speedometer/odometer/trip meter. And, they're probably the best option out there.
Out of these two:
Out of these two:
