Tire Sizes
For those of you with 15" wheels, what size tires are you running on? I'm running on 205/55/15's, but I having some doubt about them. According to the tire calculator (http://www.miata.net/garage/tirecalc.html), I'm only going 59.2 mph when the speedo says 60 mph, with the tires I'm running on http://is.rely.net/1-92-30009-l-tEzP...BTGi0jOCgA.gif . Just wanna ask around to see if there are better tire sizes to keep the speedo accurate. Thanx.
215/55/15's would be the closest 55-series sidewall.
Re: (toyomatt84)
Yeah, but I couldn't find a tire of that size https://honda-tech.com/forums/images/smilies/emsad.gif .
Re:
What would be better to run?
Out of these two: 215/55-16 or 205/55-16 Out of these two: 215/50-16 or 205/50-16 I'm actually leaning towards 215/50-16. I think i'm running 205/50-16. http://www.miata.net/cgi-bin/tirescgi I used this to compare 185/65-15 |
Re: Re: (oddmut)
I would go with 215/50/16's: more grip, better response. Just my 2 pennies https://honda-tech.com/forums/images/smilies/emthup.gif
Re: Re: (baiwldrnner)
Will it rub? - my fenders are rolled.
Would it still look like side walls? |
Re: Re: (oddmut)
Naw it won't rub. 7th-gen civics can have a tire width of up to 215mm, and a rim width of 19 inches. So ur safe https://honda-tech.com/forums/images/smilies/emthup.gif .
Sidewalls, uh, some but not too much, at least better than 15" wheels. |
Re: Re: (oddmut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut »</TD></TR><TR><TD CLASS="quote">What would be better to run?
Out of these two: 215/55-16 or 205/55-16 Out of these two: 215/50-16 or 205/50-16 I'm actually leaning towards 215/50-16. I think i'm running 205/50-16. http://www.miata.net/cgi-bin/tirescgi I used this to compare 185/65-15</TD></TR></TABLE> I have 215/50/16's on my R/C Starks. Check the picture thread for recent photos. They're identical in height to the stock size, so there's no loss/gain on the speedometer/odometer/trip meter. And, they're probably the best option out there. |
Re: Re: (toyomatt84)
So, 205/55/15 is a good size no?
Re: Tire Sizes (baiwldrnner)
i am running 205/50/15 and hey are not bad for .8 of a mph to me it is not worth changing
