I'm Selling my used 10MM Racing Magnecor Spark Plug wires set fit B-series engine
Hi everyone,
I'm selling my 10mm Racing Magnecor spark plug wire set, its used. The color is RED, I bought this Magnecor spark plug wire set last year. It's dirty on the wires but nothing affect the performance. Nothing wrong or crack, but I prefer NGK spark plug wires so just want to get rid of its. Since I have another set of ACCEL spark plug wires.
I still have the original box that the wire cable set was in and also the one sticker still there haven't used. On the box has the stock number which is 49232, which showed what car and engine this wires fit.
I'll try to get pictures from its. If anyone interest let me know...pm.
I bought brand new last year for $130 plus shipping. I see that some other website sell this over $180.
I'm selling $55.00 plus shipping.
Modified by civicx at 7:30 PM 11/3/2007
Modified by civicx at 7:32 PM 11/3/2007
Modified by civicx at 7:34 PM 11/3/2007
Modified by civicx at 6:17 PM 3/30/2008
Well....let me take pictures and upload here so you can see how its looks. I bought its last year, but over this past summer I haven't used them since I take out my b16 motor and everything out so its not running over 6months now. If you want make me a reasonable offer...
Here are some information about its...I found on the net.
"Magnecor 10mm R-100 Competition Ignition Cables
Magnecor R100 Ignition Cables are primarily designed to eliminate both EMI and RFI suppression problems resulting from the use of solid and mag style conductor ignition wires on vehicles utilizing high-output ignition systems together with sensitive on board electronic devices, including fuel, ignition and engine management systems, as well as radio and TV equipment. When used with high-output ignitions, exceptional ignition performance can be expected from domestic and foreign built race and modified engines using fuel injection, turbo charging, super charging and /or exotic fuels. Magnecor R100 Ignition Cables can also be used to advantage on engines fitted with exhaust emission controls, as well as marine engines, and severe load commercial vehicle engines particularly those using alternative fuels such as propane and natural gas with a history of persistent ignition lead failure. These engines will benefit from the ability of Magnecor Ignition Cables to conduct a high spark current at above and below normal operating temperatures.
Magnecor 10mm R-100 Competition Ignition Lead Specifications:
OVERALL LEAD ASSEMBLY
Outside Diameter of Cable: 10mm
Color: Red
Boot/Terminal Configuration: Various - to suit different domestic and foreign applications as well as customer special requirements.
CABLE
Construction Type: One piece, no cost saving layers used.
Insulator Material: Extreme heat resistant TC-1500-HS high strength aerospace silicone rubber formulated to dissipate heat away from section exposed to high temperatures.
Heat Resistance: 700oF (380oC) service temp. 1,200o F (650oC) short burst 3 minutes.
Dielectric Strength: 80kV at 260oC.
Flexibility & Strength: may need holes in separators enlarged to at least 8.5mm if large hole separators are not available.
CONDUCTOR
Conductor Size: 2.50 mm in diameter.
Conductor Type: Magnecor Metallic Inductance. RFI and EMI Suppressed.
Core: Ferrimagnetic base
Windings: 79 turns per cm (200 turns per inch).
Windings Material: Stainless steel.
Resistance: 72 ohm per cm, 2.2K ohm per ft. + 10%.
Capacity: 80 kV, 2kVA.
TERMINALS
Spark Plug: Stainless steel snap-lock 180o bendable and fixed 90o styles.
Distributor and Coil: Brass, stainless steel and beryllium snap-lock 180o and 90o styles.
PROTECTIVE BOOTS
Spark Plug: Silicone 320o C (600o F) - selection of straight, 45o and 90o styles used where applicable - special connector assemblies for some applications.
Distributor and Coil: EPDM or Silicone - some sets will be fitted with OE style connectors."
Modified by civicx at 6:20 PM 11/1/2007
Modified by civicx at 6:21 PM 11/1/2007
Color: Red
CABLE
CONDUCTOR
TERMINALS
PROTECTIVE BOOTS
Here's the pictures....enjoy its.
<p style="visibility:visible;"><object type="application/x-shockwave-flash" data="http://widget-19.slide.com/widgets/slideticker.swf" height="320" width="426" style="width:426px;height:320px"><param name="movie" value="http://widget-19.slide.com/widgets/slideticker.swf" /><param name="quality" value="high" /><param name="scale" value="noscale" /><param name="salign" value="l" /><param name="wmode" value="transparent"/> <param name="flashvars" value="cy=ms&il=1&channel=576460752327965721&site= widget-19.slide.com"/></object><p>
</p></p>
</p></p>
The pictures I uploaded above need to click image to see the pictures...here's where you can see right away......enjoy its!
On the box below the stock number 49232, has the follwoing vehicles lists...
Acura Integra GS-R. Type R, SI-R, 1992-2000
Honda Civic SI. SI-R 1999-2000
Honda Del Sol VTEC. SI-R 1994-97
Honda Civic/CRX/Integra 1600i. VTI, SI-R, TYPE-R (non-USA)
(Honda B16A2, B17A, B18C1 DOHC VTEC engines)
I tried to take pictures as close as possible but won't be able to see clear enough therefore I take coupe pictures the same.....Thanks for looking!
ApexiChild
Mar 1, 2004 04:14 AM
