boosted h23a1s......or you h22a punks...... Return Line fitting ?'s
Old Jun 22, 2002 | 02:38 PM
Accord94DX's Avatar
Default boosted h23a1s......or you h22a punks...... Return Line fitting ?'s
What size fitting for the connection in the oil pan? AN or NPT? Where the hell should i put it?
Old Jun 23, 2002 | 10:52 AM
lude98's Avatar
Default Re: boosted h23a1s......or you h22a punks...... Return Line fitting ?'s (Accord94DX)
put it above the level of the oil in your pan so it will flow freely. you should see an oil level marking on the inside of the pan when you get it off. most use a 1/4" NPT for it.
Old Jun 23, 2002 | 11:06 AM
Quaalude's Avatar
Default Re: boosted h23a1s......or you h22a punks...... Return Line fitting ?'s (lude98)
who u calling a punk? ....i used an earl -10AN aluminum weld fitting and had it TIG welded to the oil pan....i got the fitting from baker precision
[Modified by Quaalude, 3:08 PM 6/23/2002]
Old Jun 23, 2002 | 02:52 PM
Accord94DX's Avatar
Default Re: boosted h23a1s......or you h22a punks...... Return Line fitting ?'s (Quaalude)
thanks fellas
bb_one
Jul 17, 2006 10:49 PM
toolowsol
Feb 9, 2006 01:52 PM
Hondasaurs
Jan 29, 2003 08:31 AM
Evil EG
Apr 3, 2002 07:30 PM
