anbody try sticking exhuast pipe?
Old Oct 31, 2007 | 07:29 PM
suicide_shift's Avatar
* B A N N E D *
Default anbody try sticking exhuast pipe?
i read about this on the hobart forumns........someone said they did it many times with 6013 3/32" dcen low heat (said it worked becuase it was a sheet metal rod)
someone else said that the 6010 on the same setting electorode negative in the 3/32" form works well too
i had alwasy belived that 6010 was made for EP and did not produce a good weld in the EN setting
im a newb to welding anything tho
Old Nov 1, 2007 | 03:57 PM
DeadVet's Avatar
Default Re: anbody try sticking exhuast pipe? (suicide_shift)
Ive stick welded exhaust before. Doesnt come out too bad if you use the right heat and take your time. Ive used both 6010 and 7018in both 3/32 and 1/8. I also run it downhill.
Old Nov 1, 2007 | 04:36 PM
dave@passenger's Avatar
I've stick welded exhausts years ago using 6013 1/16 electrode. Turned out really nice actually, all things considered.
Old Nov 4, 2007 | 07:01 PM
J_Bone's Avatar
Yes, I've seen some very good exhaust welds with 6013. But with your exsperiance, I would recommend 7018. It's easier to lay down a good bead.
Old Nov 4, 2007 | 10:17 PM
* B A N N E D *
Default Re: anbody try sticking exhuast pipe? (J_Bone)
stupid question but like a butt joint do you give it a little space and what diameter rod should i use?
i think ill buy 5lbs of each
6013
7018
Old Nov 5, 2007 | 04:45 AM
ManBearPig4silly's Avatar
Sure why not? It's not that much fun but it works.
Old Nov 5, 2007 | 11:00 AM
wilham320's Avatar
Default Re: (ManBearPig4silly)
I used a 308l stainless rod on my stainless dp, worked really nice, and will never rust, lays as nice of bead as 7018...
a267mm
Welding / Fabrication
Mar 20, 2016 07:15 PM
cantaffordaccord
Jan 7, 2010 11:56 AM
eflove
31
Aug 16, 2008 04:01 AM
ILLICON3000
14
Sep 16, 2004 01:38 AM
MeanGreenEG9
Feb 25, 2003 01:38 PM
