Seat wobbling....*searched*
I have an 03 ex coupe,my problem is that my drivers seat wobbles in hard cornering.I checked the 4 bolts that hold the seat down and they are tight. No matter where I slide my seat to it wobbles.I'm not able to wobble the seat unless i'm sitting in it,so I cant wobble it with my hands and look under to see what it is.I never noticed when my car was stock, but ever sense I dropped it and put a rear progress sway bar on, you can really feal it,at first barely at all to worse and worse.I plan on getting EP3 seats in the future, but I just want to fix this problem because it can not be safe.
p.s.Happy Holloween, dont drink and drive.
......just drink.
......just drink.
This has been covered before, but I couldn't locate the Technical Service Bulletin on the forums, so I did the research for you.
* TSB #01057 -- DRIVER'S SEAT THAT ROCKS BACK AND FORTH DURING NORMAL DRIVING. *TT *MJ *TT *EH (NHTSA ID #633594, FEBRUARY 22 2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iGGY366 »</TD></TR><TR><TD CLASS="quote">Would this be a warranty fix? I'm having the same problem.</TD></TR></TABLE>
they'll fix it if you're not in warranty, it's a TSB, it's seperate from warranty... (correct me if i'm wrong.)
I did this recently, it was a rather expensive fix for such a small item ($50.00). What I found out though is it is the rear bushings that go bad. If you just replace them and reuse the hardware it is cheap repair. Just remember to lubricate with a lithium grease.
From A Buick 8
Feb 28, 2015 06:08 PM
electronspeeder
20
Apr 2, 2002 03:24 PM
