FUEL ISSUES ON MY H22 HATCH. HELP PLEASE.
Old Oct 31, 2007 | 12:05 PM
ludatic98's Avatar
Default FUEL ISSUES ON MY H22 HATCH. HELP PLEASE.
Yesterday i went to start my car and it had been running good until now. anyway when i started it, it ran for about two minutes then it bogged down and died. it showed a loss in fuel pressure and it would just sit there and crank. then the battery went dead so hooked up the charger and tried it again.
i ended up pulling my plugs and they were fouled beyond beliefe and the cylinders were full of gas so i cranked the motor with the plugs out and shot fuel out the cylinders to the roof.
i cannot figure out why my injectors would have got stuck wide open like that.
is there any way to really check to see if they are still stuck open? i bought some new plugs and i just wanted to know if i should breakdown and buy new injectors or just try again and see if they will work.
any help wpuld be great thanks
Old Oct 31, 2007 | 05:30 PM
roller3804's Avatar
Are the injectors from the original motor? Are you using a p13? Its possible they are dirty and need to be cleaned.
Old Oct 31, 2007 | 05:56 PM
JTCdudeman's Avatar
Master H Technician
Default Re: (roller3804)
+1 for thinking its spark and not fuel....
try some cheap plugs out and see if it runs..
slvrcvc93
21
Apr 12, 2010 08:21 PM
lhd dc2
22
May 11, 2009 05:21 PM
Dave_Dc2
Mar 14, 2009 09:05 PM
phreakmang
Jul 26, 2004 06:01 AM
ID_ten_T
Mar 6, 2004 09:04 PM
