water in my cars
Old Oct 30, 2007 | 05:55 PM
oldskoolDA6's Avatar
Default water in my cars
hello peoples, i have a situation here. just brought a DA6, sat in my drive way for a few days....rain a lot. then i noticed a lot of condensation inside my car. when i reached and touched the floor mats. they were soaking wet, and i went and checked the trunk, it was wet as well. So, what is the problem here? water coming in from the trunk?? please need help, the car starting to smell like wet socks... thanks
Old Oct 30, 2007 | 06:08 PM
SleeperGSR's Avatar
Default Re: water in my cars (oldskoolDA6)
Make sure your windows are up? If they are not put them up. If the are up, sit inside an look to see where the water is comming in, fix the hole.
Old Oct 30, 2007 | 06:10 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: water in my cars (SleeperGSR)
Yea while its raining take a flash light and look around everywhere!
Old Oct 30, 2007 | 07:33 PM
vtec8804's Avatar
* B A N N E D *
just sit in the car and have a friend hose u down lol
Old Oct 30, 2007 | 07:41 PM
Th3savinday's Avatar
water from the trunk can be stopped by putting a bead of silicone around the top of the taillights where it meets the top of the trunk.
Old Oct 30, 2007 | 07:55 PM
Redemption's Avatar
This is a common problem with the DA's. The window stripping, the rubber parts after years doesnt hold water back very well. You just need to take out the window stripping, clean it, and when putting it back on use some silicon.
Old Oct 30, 2007 | 09:55 PM
Jtuned DC2's Avatar
* B A N N E D *
yea Check this site out. it tells you how to fix little problems with DA's like the jumping speedo needle.
http://www.g2ic.com
This is your problem right here
http://g2ic.com/tegtips/interior/15.html
Old Oct 31, 2007 | 02:37 AM
DVSBIZZYB's Avatar
Most likely you have the notorious "passenger floor leak problem" that I'm sure most DA owners have gone through. It happened to me and I fixed it with no problems. Here is the thread on how to fix it.
http://www.g2ic.com/forums/sho...pp=20
On page five there are some pictures.
As for the trunk being wet, it might be leaking from the taillights... just change the gaskets. My problem was the antenna.
http://www.g2ic.com/tegtips/interior/16.html
Old Oct 31, 2007 | 06:09 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskoolDA6 &raquo;</TD></TR><TR><TD CLASS="quote">hello peoples, i have a situation here. just brought a DA6, </TD></TR></TABLE>
as an aside, unless you have a true jdm honda integra then you don't have a DA6, you have a DA9 ....sorry to burst your bubble but there's no need for you to go around looking uneducated
Old Oct 31, 2007 | 06:38 AM
dizzzane's Avatar
Default Re: water in my cars (GRAF-FITI)
I was unaware of the DA floor leak issue, I was going to suggest your seals/weather stripping have deteriorated due to time and aging. I wouldn't think the floor leak would make its way to the trunk, but given enough time I guess thats a possible solution.
And thanks to th3savinday, I have had this leak issue in my trunk and was positive the tailights were causing the problem, Thanks man.
And...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
as an aside, unless you have a true jdm honda integra then you don't have a DA6, you have a DA9 ....sorry to burst your bubble but there's no need for you to go around looking uneducated</TD></TR></TABLE>
Missed the thread related response... atleast you helped though.
Old Oct 31, 2007 | 06:40 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: water in my cars (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">
Missed the thread related response... atleast you helped though.</TD></TR></TABLE>
the gentleman posted mis-information in his thread, and i corrected him....thus it's a thread related response
Old Oct 31, 2007 | 06:52 AM
dizzzane's Avatar
the gentleman posted mis-information in his thread, and i corrected him....thus it's a thread related response </TD></TR></TABLE>
Touche.
Old Oct 31, 2007 | 01:51 PM
sorry for the miss info, you're right it is a DA9 my bad. yep, trying to fix the problem...thanks everyone for their input.
CooperNOLA
Honda CR-V & Element
May 6, 2017 09:15 AM
kaboose79
Nov 22, 2016 07:43 AM
Tenassi
May 19, 2011 10:43 PM
dlenoxx
Dec 2, 2010 12:05 PM
Arvid
May 11, 2003 08:35 AM
