cylinder head swap
Wud up ppl. hey im new here so im still learning about these forums. I got an 01 civic w/ a d17a1 and recently got a head off of a a2. im gonna have it machined and all but at the same time i wanted to but better cams, springs, valves, etc... where can i find all this stuff. im building this car for street and track. so i need something that will fall in between these 2 categories. plus once i get the head in, how do i make the vtec function properly, since it won't be hooked up to the ECM. all answers will be greatly appreciated. thanks.
Dont bother spending $1500 for 10 whp..with that your already half way to a Turbo upgrade... just pnp your stock head and get bigger pistons and rods then turbo... you woould be able to get like 250whp @ 10psi( i think.. correct me if im wrong guys)
you wont be spending 1500 for a head swap... you could get it for alot less if you shop around. probablly 600-1000 MAX for parts in a junk yard. then just DIY it.
3k for a turbo build is possible. 250whp @ 10PSI is doable too but NOT at 3k. Hell, kpro alone is about 1300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1759217
read and be done with it. </TD></TR></TABLE>
DA 4 Lyfe
Nov 9, 2012 03:54 PM
MauiEg
Jan 19, 2006 03:35 PM
