EF y8 problem
Old Oct 30, 2007 | 04:39 PM
thesoundofturbo's Avatar
Default EF y8 problem
does code 10 IAt sensor cause my car to redline after startup?i wasnt to sure about it
cause ive had this problem for awhile and kant figure out the problem.my engine is a y8 running obd0 but i have a Z6 intake manifold on it with the z6 throttle body i dont know if the z6 throttle body works with it since its obd1.i tried my A6 throttle body but it doesnt fit on it.so what can be the prblem for my car to redline?might be my vacuum lines too but i dont kno if i plugged it in the right plug since its a z6 manifold so it has different locations
any info would be helpful thanks
Old Oct 30, 2007 | 05:01 PM
jlicrx's Avatar
Default Re: EF y8 problem (thesoundofturbo)
high idle rpm is either throttle cable too tight or a big vacuum leak - the code 10 TA sensor probably means you have the wrong connector plugged into the sensor - the TA sensor has a 2-wire connector with red with yellow stripe and green with white stripe wires
Old Oct 30, 2007 | 05:07 PM
EF9 JAMS!!!'s Avatar
Default Re: EF y8 problem (jlicrx)
maybe your tps?
Old Oct 30, 2007 | 05:13 PM
Default Re: EF y8 problem (EF9 JAMS!!!)
ill check on that plug for code 10 and if it was my tps wouldnt a code come on for it?
or can it just be the throttle body since im using the z6 one and its obd1?cause theres 2 plugs on it unless i can use it and i just plugged in the wrong sensor on the TB?
Old Oct 30, 2007 | 05:18 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesoundofturbo &raquo;</TD></TR><TR><TD CLASS="quote">ill check on that plug for code 10 and if it was my tps wouldnt a code come on for it?
or can it just be the throttle body since im using the z6 one and its obd1?cause theres 2 plugs on it unless i can use it and i just plugged in the wrong sensor on the TB?</TD></TR></TABLE>yes, TPS would give you Check Engine Light - using the Z6 throttle body shouldn't be a problem - it has the MAP sensor on top where your car has a MAP on the firewall - you can use either one, although i prefer the one on the throttle body - the TA sensor is on the back of the intake manifold toward the driver's side - it is white diamond shaped where it attaches to the manifold - i would bet on a vacuum leak being the cause of the high idle
Old Oct 30, 2007 | 05:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">yes, TPS would give you Check Engine Light - using the Z6 throttle body shouldn't be a problem - it has the MAP sensor on top where your car has a MAP on the firewall - you can use either one, although i prefer the one on the throttle body - the TA sensor is on the back of the intake manifold toward the driver's side - it is white diamond shaped where it attaches to the manifold - i would bet on a vacuum leak being the cause of the high idle</TD></TR></TABLE>
so where do i plug the lines komming out of the map sensor on the firewall?
and theres 2 plugs on the throttle body which one would i plug into? theres one near the firewall and one right on top of it.and i wouold plug one of the 2 and i just leave the other unplugged?thanks for your help man
Old Oct 31, 2007 | 06:43 PM
any1 have a answer?
sasinorm01
May 21, 2012 04:48 AM
hkboy87
Jul 10, 2007 07:52 PM
Mach69
May 16, 2005 07:02 PM
EGbeater
Nov 21, 2003 07:12 AM
spun Vtec
Jan 31, 2003 08:42 AM
