d16 throttle body question
I currently have a y7 engine in my car (stock). I would like to upgrade to a y8 intake manifold. The problem is that the throttle body on the y8 mani is missing the TPS sensor. So my question is can I use my y7 TPS sensor on a y8 throttle body?
Re: d16 throttle body question (hkboy87)
Yes, you can use a pair of dykes or take a dremel very slowly to the nuts, you will need two bolts of course (easy) and a voltmeter to calibrate it. The TPS should read .49-.50V CLOSED, and around 4.50V WOT, you will need to clock the TPS to the right voltage, or you will have a very rapid idle surge.
cool, i just needed to know if the y7 TPS sensor will fit a y8. I'm going to take this to a shop and hopefully they should know how to do this.
ATLien6
06-02-2012 01:53 PM
sasinorm01
05-21-2012 04:48 AM
