H22 went dead! electrical?
Old Oct 30, 2007 | 10:01 AM
H22poweredEJ8's Avatar
Default H22 went dead! electrical?
ok i was doing 70 down the highway going home. my car just dies on me. everything went dead, no headlights nothing. what could it be? only thing that works on my car as of now is my hazards
things checked:
battery
battery fuse
fuse block/fuse
checked the power cable to see if it was grounding out
Modified by H22poweredEJ8 at 10:47 AM 10/31/2007
Old Oct 30, 2007 | 10:03 AM
EGJason's Avatar
Default Re: H22 went dead! electrical? (H22poweredEJ8)
Alternator, or a connection from/to it.
Hook up a new battery to it that you know has juice. If it turns, it's your alternator.
Old Oct 31, 2007 | 09:38 AM
Default Re: H22 went dead! electrical? (EGJason)
i do have a inline to it, i replaced it and i replaced the battery. i replaced the battery fuse also. could it be a bad power cable going from the batery to alt.??
Old Oct 31, 2007 | 09:48 AM
sleepyH22's Avatar
try changin the main relay for a known good one...
use a testlight and check for shorts...electrical problems are quite simple..i fixed Alot of wiring on my civic when i did my h22 swap..its a wiring mess but everything works.. some weird stuff happens with a h22 in a civic..just find the problem and fix it..cant be too much trouble.
Old Oct 31, 2007 | 12:55 PM
EGJason's Avatar
Default Re: (sleepyH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 &raquo;</TD></TR><TR><TD CLASS="quote">try changin the main relay for a known good one...
Knock out simple things that you can just plug in and test first. ECU, relays, battery, grounds. Stuff like that. THEN go wire hunting.
Old Oct 31, 2007 | 04:51 PM
well idk why i never thought of that.
ill check the main relay. becuz im getting power to the battery, inline fuse, alt., everything just none to the car.
Old Oct 31, 2007 | 07:00 PM
crxricer66's Avatar
Default Re: (H22poweredEJ8)
this may sound stupid, but your ground for your battery. had same thing happen to me, take the battery clamp off clean it real good or cut and resplice.
Old Oct 31, 2007 | 09:14 PM
Default Re: (crxricer66)
thanks but i tried that too.
Old Nov 5, 2007 | 07:21 PM
ok guys im still stuck. i just dont get anything electrical
Old Nov 5, 2007 | 07:37 PM
marshun's Avatar
i got a h22 ek too
any fuses popped? go through'em wtih a check light.
gauge lights come on when the key is in the on position?
one problem that gave me a couple of bad hours was a crazy alternator. it would pop the battery fuse. disconnect the alternator and try n crank it. thats the alternator
Old Nov 5, 2007 | 07:43 PM
i get nothing when i turn the key. no power at all. no beeping no lights no ignition. from what i can tell all my fuses are good and im getting power to everything under the hood. ppl tell me iit could be my ignition, but that doesnt explain why i can even get power to turn my headlights on
Old Nov 5, 2007 | 07:57 PM
ttt
Old Nov 5, 2007 | 08:40 PM
darktuner's Avatar
i would still check the ignition switch. just get a cheap multimeter and stark checking things. get a repair manual with wiring diagrams in it and check all switches relays also check resistances of all major battery cables. from the battery to the fuse block. if you have power at the ignition switch then you should be able to start it will be a big white wire under the steering cover. ill look at the wiring diagram tonight and tomorrow and see what i might find for ya
Old Nov 6, 2007 | 09:45 AM
thank you that would be helpful. im gunna give it a few more looks and see what i can find
Old Nov 6, 2007 | 10:46 AM
brian...'s Avatar
check your actual ignition switch i had the same thing happen to me on my accord back in the day and i had to replace the whole thing.
Old Nov 6, 2007 | 05:08 PM
Boost'd EJ1's Avatar
check all grounds. i had same problem car stop running no power to nothing but when i rocked the car i would get power for a second. spent over a week replacing all harness and it was 1 grond came loose and 1 not a good contact on valvecover.
willfly
Oct 14, 2015 04:07 PM
Tip14
Dec 27, 2007 01:13 PM
phase7
Feb 20, 2007 07:16 AM
idteg
Nov 1, 2004 10:46 AM
Tad
Oct 31, 2004 12:24 PM
