Sump on plastic tank?
Not sure if this is the correct forum for this but seems fitting
Either way i was wondering if anyone has done a sump on a plastic gas tank before, and if so where did you get it from and how did you go about it? I really dont want to go to a fuel cell and well i just dont trust the transfer pump/stock tank setup.
Any help would be much appreciated
thanks
tommy
thanks
tommy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">we have done it a couple times, i will see if i can dig up some pics for you.</TD></TR></TABLE>
thatd be awesome. ANyone know of anyone who sells a plastic sump? i havent even found one on jegs/summit or anything like that.
huh? ok i have a 02 si https://honda-tech.com/zerothread?id=2103514 with fuel cell in there now but i heard that to run at track with a hatchback i need a stock tank so the stock tank is plastic so trying to figure out what to do. thanks for any help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com »</TD></TR><TR><TD CLASS="quote">Why not just run a surge tank? </TD></TR></TABLE>
this would be the ideal option IMO also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx »</TD></TR><TR><TD CLASS="quote">surge tank ?</TD></TR></TABLE>
the surge tank is really an ideal setup, as there will never be fuel starvation if made properly
basically you use two fuel pumps and the first one simply keeps the surge tank full, which is feeding the engine
ill make a diagram for you if you want
SoullessJapaneseMachine
Jan 17, 2008 08:53 AM
