Sump on plastic tank?
Old Oct 29, 2007 | 10:23 PM
TommyC83's Avatar
Default Sump on plastic tank?
Not sure if this is the correct forum for this but seems fitting
Either way i was wondering if anyone has done a sump on a plastic gas tank before, and if so where did you get it from and how did you go about it? I really dont want to go to a fuel cell and well i just dont trust the transfer pump/stock tank setup.
Any help would be much appreciated
thanks
tommy
Old Oct 30, 2007 | 10:46 AM
miller's Avatar
Default Re: Sump on plastic tank? (TommyC83)
we have done it a couple times, i will see if i can dig up some pics for you.
Old Oct 30, 2007 | 01:27 PM
paulzy's Avatar
plastic welder for motorcycle fairing panels might work.
Old Oct 30, 2007 | 05:08 PM
TommyC83's Avatar
Default Re: Sump on plastic tank? (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">we have done it a couple times, i will see if i can dig up some pics for you.</TD></TR></TABLE>
thatd be awesome. ANyone know of anyone who sells a plastic sump? i havent even found one on jegs/summit or anything like that.
Old Nov 9, 2007 | 06:44 PM
TommyC83's Avatar
bump for any ideas i really dont want to use a cell
Old Dec 22, 2007 | 12:03 PM
mini-cRx's Avatar
ttt interested also
Old Dec 22, 2007 | 02:33 PM
jon volk's Avatar
Default Re: Sump on plastic tank? (mini-cRx)
If the plastic welding deal works for bonding it then just cut the sump out of a plastic fuel cell.
Old Dec 22, 2007 | 04:49 PM
*Boostwerks*'s Avatar
Why not just run a surge tank?
Old Dec 22, 2007 | 05:35 PM
mini-cRx's Avatar
Default Re: (Boostwerks.com)
huh? ok i have a 02 si https://honda-tech.com/zerothread?id=2103514 with fuel cell in there now but i heard that to run at track with a hatchback i need a stock tank so the stock tank is plastic so trying to figure out what to do. thanks for any help guys
Old Dec 22, 2007 | 07:57 PM
MajorPayne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">Why not just run a surge tank? </TD></TR></TABLE>
this would be the ideal option IMO also
Old Dec 23, 2007 | 04:11 AM
mini-cRx's Avatar
Default Re: (MajorPayne)
surge tank ?
Old Dec 23, 2007 | 09:43 AM
MajorPayne's Avatar
Default Re: (mini-cRx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx &raquo;</TD></TR><TR><TD CLASS="quote">surge tank ?</TD></TR></TABLE>
the surge tank is really an ideal setup, as there will never be fuel starvation if made properly
basically you use two fuel pumps and the first one simply keeps the surge tank full, which is feeding the engine
ill make a diagram for you if you want
Old Dec 23, 2007 | 10:58 AM
bigTom's Avatar
does anybody have anything against BOLTS!?
the plastic sump n glue idea I just dont trust; especially when it comes down to dealing with fuel.
Old Dec 23, 2007 | 05:11 PM
mini-cRx's Avatar
Default Re: (bigTom)
so tom how do i do this then. help would be appreciated thanks
what do u mean anything against bolts ?
Old Dec 24, 2007 | 03:09 AM
mini-cRx's Avatar
Blue00Si
Apr 25, 2008 04:07 PM
SoullessJapaneseMachine
Jan 17, 2008 08:53 AM
dynamitezz
Oct 3, 2006 05:57 AM
Soon_2b_evil
Oct 12, 2004 10:53 AM
