RC 550cc/min injectors... Lucas disc???
Old Jun 22, 2002 | 12:45 AM
PyroVTEC's Avatar
New User
Default RC 550cc/min injectors... Lucas disc???
For a F/I SOHC running 1bar of boost... is the Lucas disc spray pattern the ideal one for a daily driver??? I had no idea what spray pattern I had until I took a look at the spec sheet that came with the injectors...
The RC spec sheet says:
INJECTOR TYPE: P&H 2.5
INJECTOR MAKE : LUCAS
At least I know that the injectors are of the low-impedance sort, so I'll be able to use in conjunction with the resistor pack, but is the spray pattern proper for my application??
Old Jun 22, 2002 | 04:45 AM
Rocket's Avatar
Default Re: RC 550cc/min injectors... Lucas disc??? (PyroVTEC)
Lucas type disc injectors have a more concentrated laser beam style "squirt" pattern that is well suited to penetrating a high velocity air stream.
They won't mist like a pintle injector so low rpm atomization won't be as good but higher rpm is real nice.
Also the disc type injectors are much faster and your car won't burble when you let off the gas.
They'll be fine for daily driving if tuned properly.
Old Jun 22, 2002 | 05:08 AM
turbo Si's Avatar
Default Re: RC 550cc/min injectors... Lucas disc??? (Rocket)
Spray pattern? So ya'll do'nt think they would work well, overall?
Old Jun 22, 2002 | 06:05 AM
Rocket's Avatar
Default Re: RC 550cc/min injectors... Lucas disc??? (turbo Si)
Yes, I like they way they perform.
Old Jun 22, 2002 | 10:02 AM
93LSivic's Avatar
Hehe, I like the burble--sounds cool.
Also sometimes with the Lucas you will notice that coming from a short blip of the throttle coming back down to idle, the motor will struggle for a sec to catch back up to normal idle range--at least for me anyways.
Old Jul 1, 2002 | 11:07 PM
PyroVTEC's Avatar
New User
Default Re: RC 550cc/min injectors... Lucas disc??? (93LSivic)
Alright... phew! I just hope that it's still a daily-drivable injector!
Thanks guys!
Old Jun 27, 2003 | 12:32 PM
DC2R714's Avatar
Is it true that they are the same design as RC injectors?
Old Jun 27, 2003 | 12:46 PM
Rocket's Avatar
Default Re: RC 550cc/min injectors... Lucas disc??? (DC2R714)
RC doesn't make any injectors. They sell injectors they calibrate. Their popular line of injectors are Lucas injectors.
Old Jun 27, 2003 | 12:54 PM
DC2R714's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">RC doesn't make any injectors. They sell injectors they calibrate. Their popular line of injectors are Lucas injectors.</TD></TR></TABLE>
Thanks for the info Rocket
Old Jun 27, 2003 | 12:59 PM
Rocket's Avatar
B18bturbo sells these injectors and he also sells the better Rochesters. Hit him up. He's a good guy and helps me alot.
b18_ef_hatch
11
Mar 5, 2006 10:21 AM
nholmes
Jan 10, 2005 08:13 PM
D-Man
Jan 10, 2004 01:19 PM
oday
Aug 6, 2003 02:10 PM
