speed sensor/thermostat problem
Old Oct 29, 2007 | 07:46 PM
rtrsl's Avatar
New User
Default speed sensor/thermostat problem
has anyone had problems w/ their speed sensor n reverse light??? i've changed out speed sensor...thought it was the wire harness changed that too, still not workin...also thermostat won't open w/ motor runnin but tested w/ boiling water it opens...any suggestions???
Old Dec 6, 2007 | 01:47 AM
n4rk0's Avatar
New User
Default Re: speed sensor/thermostat problem (rtrsl)
i have the same problem in my car '00 EM1 Civic Si my speed sensor doesnt work and my reverse light either
Old Dec 6, 2007 | 04:35 AM
B16B_coupe's Avatar
HRD PKR
Default Re: speed sensor/thermostat problem (n4rk0)
so you replaced your vss? correct?
and your reverse lights dont work'?
your really confusing. how is the thermostat ground?.
Old Dec 6, 2007 | 05:04 PM
blk92_d16's Avatar
What model do you have? My '92-'95 model year has a reverse "sensor" I had to replace; it's on top of the tranny...I needed a Cresent wrench to get it off.
1Ek 1Eg
Jan 13, 2006 02:14 PM
chris78
Jun 6, 2005 06:01 PM
951dc5
Feb 13, 2005 10:48 AM
Mike95lude
Feb 18, 2002 09:50 PM
